AC Problem
Old Aug 16, 2007 | 01:55 PM
zg1256's Avatar
zg1256
Default AC Problem
Having a problem with my AC. Will blow cold air fine for about 15-20 min, blows hot. Turn it off for a while and same thin hapens, cold then hot. Have had charge checked with RobinAIR machine, charge is ok. Replaced both High and Low switches but was no help
Any Ideas?
Old Aug 16, 2007 | 07:38 PM
Chris's Avatar
Chris
Default RE: AC Problem
Have you looked for a leak in your system? Is your system staying charged?
Old Aug 16, 2007 | 08:43 PM
imnothot02's Avatar
imnothot02
sounds to me like a pressure switch...
Old Aug 17, 2007 | 01:52 AM
boohoops's Avatar
boohoops
my guess is a leak..u should jusditch ur A/C. it robs power anyways and besides, if u need to cool off, thats wat th windows r for =)
Old Aug 17, 2007 | 07:55 AM
imnothot02's Avatar
imnothot02
if it were a leak it would not run for 15 min... it would mabie go for a min or two
Old Aug 18, 2007 | 07:58 AM
zg1256's Avatar
zg1256
Pressure switches are new. Holds charge fine
Old Aug 18, 2007 | 10:45 AM
speedyshelby's Avatar
speedyshelby
Sounds like it freezing up.
Old Aug 18, 2007 | 11:34 AM
imnothot02's Avatar
imnothot02
hmm is it full of liquid instead of gas, purge the system...
Old Aug 19, 2007 | 11:35 AM
hillfam4's Avatar
hillfam4
Replace the orifice tube in the liquid line (about 4 bucks). You should also replace the accumulator/drier/filter anytime you open up the system.
