Speed Sensor location
Old 08-20-2007, 10:56 AM
1999dakota's Avatar
1999dakota
1999dakota is offline
Default Speed Sensor location
I need to replace the speed sensor on my 1999 Dakota 4X4, 5 speed manual. Where is it located? I know it shouldn't be all that hard to but, I'm not sure of its location. Thanks for the help.
Old 08-20-2007, 12:06 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
Default RE: Speed Sensor location
well there are 2 speed sensors, what is the reason that you are replacing it, did it throw a cel? or did your speedometer stop working,
if your speedometer stopped working and/or your brake and abs lights are on that is the rear wheel speed sensor, located on top of the rear differential(sp),
~$50 for the part
if your truck threw a cel p703 (i think might not be the right number) than it is located on the drivers side of the transmission just a little bit forward of the driveshaft(the only electrical connection underneath there)
~$20 for the part
Old 08-20-2007, 01:30 PM
1999dakota's Avatar
1999dakota
The ABS light is on and the speedometer kicks in around 65mph. Thanks!
Old 08-20-2007, 02:39 PM
shrpshtr325
THE ULTI-MOD
no problem, glad to help
Quick Reply: Speed Sensor location
