Blinker fix?
Old Aug 25, 2007 | 05:18 PM
joe472set's Avatar
joe472set
Default Blinker fix?
So in my dads 04 quad cab slt the passenger blinker in the front is out. Its not the bulbs and not the fuse. Could it be the relay? If so where is the relay located.
thanks
Old Aug 25, 2007 | 05:29 PM
dodgerules86's Avatar
dodgerules86
Default RE: Blinker fix?
There is no relay, there is a box, called the combination flasher, located on the lower left side of the intrument panel.
But, I'd make sure the wiring is good.
Old Aug 25, 2007 | 10:04 PM
imnothot02's Avatar
imnothot02
buy a meter im guessing ya have a bad ground....
Old Aug 26, 2007 | 01:42 PM
suicidecustom's Avatar
suicidecustom
always check your grounds first.
