2004 cruise control problem
Old Aug 30, 2007 | 12:56 PM
snikr's Avatar
snikr
Default 2004 cruise control problem
I just bought a used 2004 Dakota Quad Cab SXT with 13000 miles on it (4.7 V-8). I'm having an interminent problem with the cruise control now. Sometimes the cruise will NOT turn on (I hit the switch but the cruise light doesn't come on). And yes the horn does work when the cruise doesn't turn on so I don't think it's the clock spring.(I did do a search but couldn't find what I was looking for). This has only happened maybe twice in a couple of weeks. Any ideas what to check? It has been back to the dealer as it's still under warrenty for a couple more months. The dealer couldn't get it to act up (lucky me). Thanks.
Tom
Old Aug 30, 2007 | 01:05 PM
Chris's Avatar
Chris
Default RE: 2004 cruise control problem
Sounds like the connection inside the steering column. If the light does come on and it is still acting up, check the vacuum line.
Old Aug 30, 2007 | 01:37 PM
snikr's Avatar
snikr
So far whenever the cruise will turn on it works. The dealer did think of the clock spring as well but the horn does work even when the cruise can't be turned on. If anymore information is needed just ask.
Tom
Old Aug 31, 2007 | 12:04 PM
Chris's Avatar
Chris
Just because the horn works, doesn't mean the wiring through your steering column is OK. My air bag light is on and my cruise control doesn't work (I am going to look into the wiring this weekend if I get the time) however, my horn still works. So don't be too quick to rule it out.
Old Aug 31, 2007 | 05:50 PM
snikr's Avatar
snikr
I just heard from the dealer I bought it from and he as much said the same thing. The clock spring wiring could be a problem even if the horn works and the air bag light doesn't come on. Or they said it could be a speed sensor that is acting up. Time will tell. Thanks for your help Virused. I'll keep everyone posted when it gets fixed.
Tom
