ABS light??
Old Sep 4, 2007 | 12:08 AM
Big_Green's Avatar
Big_Green
Default ABS light??
So i have been noticing when i have started my truck the past few times. The ABS light has stayed on after the truck is running. Well not for long. I will turn in over and it will stay on for maybe 2 seconds thats it? What could be the problem?
Old Sep 4, 2007 | 03:00 PM
Chris's Avatar
Chris
Default RE: ABS light??
Check your fluid levels and make sure it is clean fluid.
Old Sep 4, 2007 | 08:17 PM
imnothot02's Avatar
imnothot02
clean out ur tone rings possibly dirt in them
Old Sep 9, 2007 | 02:39 PM
Big_Green's Avatar
Big_Green
ORIGINAL: imnothot02
wat are tone rings?
also virused my fluid is dirty so im guessing maybe thats wat is causing it?
Old Sep 9, 2007 | 11:56 PM
master tech's Avatar
master tech
Site Moderator & Tech
Some brake lites and abs lites will stay on after a car or truck has been started and running up to 5seconds. thie is normal, its called a bulb ck. If you had a problem the lites would stayed on and give you some fault codes too.
