front end
Old Sep 15, 2007 | 09:44 PM
Pauls 00 Dak's Avatar
Pauls 00 Dak
Default front end
I have read the posts about alot of owners haveing to replace the ball joints, my question is how do you know if you need to replace them or not?
Does the truck handle differently or what?
Thanks!
Old Sep 16, 2007 | 12:16 AM
klings designs's Avatar
klings designs
Default RE: front end
Most of the time they just drop, and you have to get it towed and fixed... !
Old Sep 16, 2007 | 12:21 AM
jonnymagnum's Avatar
jonnymagnum
ya, when your front tire falls off..... its time to replace it
but if you jack up the truck and try to move the tire up and down. and if theres any play in it, then they are shot.
Old Sep 16, 2007 | 03:21 AM
Pauls 00 Dak
Thanks for the info!!
I would rather find the problem before the tires fall off while me or my 17 year old son is driving down the road.
Old Sep 18, 2007 | 12:13 AM
rred's Avatar
rred
isn't poor tire tread wear another sign?
Old Sep 18, 2007 | 03:11 PM
jonnymagnum
ORIGINAL: rred
ya, it can mean that or it needs an alignment.
Old Sep 18, 2007 | 04:17 PM
Pauls 00 Dak
So far the tires seems to be wearing fine so hopefully mine will be ok.
I have alse read that you can jack up the truck and grab the wheel and jerk back and forth and if there is a lot of side to side movement then they may need changed.
Old Sep 19, 2007 | 10:18 AM
yellowjacket99's Avatar
yellowjacket99
ORIGINAL: Pauls 00 Dak
When you jack it up, put your hands at 12 o'clock and 6 o'clock, if there's play that way then it's your ball joints. If there's play with your hands at 3 and 9, then it's tie rods. Someone correct me if I'm wrong, but that's what I've always been told.
Old Sep 19, 2007 | 11:38 AM
Pauls 00 Dak
Cool deal thanks for the info guys!
Old Sep 19, 2007 | 12:37 PM
Chris's Avatar
Chris
ORIGINAL: yellowjacket99
That is correct.
