Alchohol Injection
Old Sep 20, 2007 | 07:43 PM
98whitekota's Avatar
98whitekota
Default Alchohol Injection
Alchohol Injection how dose it work???? what the power advantage ? how much is? any one that has it give me all the info u can thnx
Old Sep 20, 2007 | 08:56 PM
imnothot02's Avatar
imnothot02
Default RE: Alchohol Injection
oh geez
Old Sep 20, 2007 | 09:15 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I dont know exactly what you would have to do but I have heard myths like you have to pour cement into you cooling block to streathen it. and who knows if you have to!! But this is a cool site for anything to do with racing. It have info on building engines for superchargers nitrus and alot more search around you might find it. http://www.grapeaperacing.com/tech/
Old Sep 20, 2007 | 10:41 PM
imnothot02's Avatar
imnothot02
yea fill it with cement
Old Sep 20, 2007 | 11:05 PM
User's Avatar
User
uh................ WHAT~
sheesh...
Old Sep 20, 2007 | 11:07 PM
DAKNBLK's Avatar
DAKNBLK
I think you have to use synthetic headlight fluid.
Old Sep 21, 2007 | 12:23 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Okay I found a good site for it http://www.geocities.com/rad87gn/tech/alcohol.html
I think this is the filler you use like some kind of cement. http://store.summitracing.com/partde...p;autoview=sku
Old Sep 21, 2007 | 07:44 AM
imnothot02's Avatar
imnothot02
hahah lol i heard ya just use the stock motor filler up! leter rip!!
Old Sep 21, 2007 | 12:05 PM
rtkota5point9's Avatar
rtkota5point9
Come on guys... I don't think he's talking about an achohol fueled engine. "rolls eyes" lol He's talking about alchohol injection as it pertaines to adding it to a gasoline engine.
I'm running alky injection from Kennedy's Dyno Tune.Basically you set it for a certain RPM to kick in, and on mine I have a pressureswitch that willonly allow it to kick in while im in boost, not just cruising down the highway. There is a tank, a pump, and a nozzle that goes in the airhat. I used my windshield washer bottle as the tank because it holds nearly a gallon (which usually lasts mea whole tank of gas) and it lets you know right on the dash when it's low cuz the "LOW WASH" light will come on. Plusthe mix works great for windshield washer fluid too (although the smell is strong when you do that) You can runhalf/half methonol and distilled water,rubbing alhohol (80% or above)and distilled water, or even straight washer fluid which basically consists of... methonol and water . I run the alky/water mix.
The alchohol injection alone doesn't add much, if any power. The advantage of the alchohol injection is it reduces combustion chamber temperatures. The reduced temp, along with the little bit of added octane from the alchohol allows you to run more timing without getting pre-detonation. The advanced timing is what actually gives you the power, not the alchohol. It's especially useful in boosted applications because you need to retard a lot of timing with the stock compression ratio, otherwise you'll get pinging. With the alky, you can pretty much run no timing retard at all, which gains you quite a bit of power.
You could use it on an N/A setup, as long as you had some way of controlling the timing so you could advance it. But the benefits over cost on an N/A engine is not going to be nearly as much as in a boosted application.
Hope that clears up some things.
Old Sep 21, 2007 | 12:47 PM
Twiztid's Avatar
Twiztid
Good to see someone give a real answer. I all I saw before you posted was a bunch of people showing they know nothing of the topic and just wanted to bash someone.
+1 for 5point -10 for the rest of you
