Budget Intake
Old Sep 24, 2007 | 02:13 AM
flipzkid's Avatar
flipzkid
Default Budget Intake
Has anyone actually made this intake from the Tips and Tricks site? It talks about buying a plastic tubing from Home Depot and a K&N Cone Filter and making a budget intake from that. I guess that means that you'll be keeping the airbox but I'm not sure if I have to remove that filter box or keep it? Also, if anybody's done it, can you post a pic please! Thanks.
Old Sep 24, 2007 | 05:31 PM
Chris's Avatar
Chris
Default RE: Budget Intake
You would need to remove you stock airbox to create the named intake. Use the search function, as this subject has been covered numerous times with complete write-ups.
Old Sep 24, 2007 | 08:27 PM
skeeter0288's Avatar
skeeter0288
i made one.the hose went from the rectangular hole in the front bumper cover,up and over the radiator/fan shroud and directly into stock air box after removingfactory inlet tube.approx $13.00.i did away with it after driving my car through water after a rain storm-had i been driving the truck the water would have been up over the intake tube.don't want to push water into the engine.replaced stock air box with a dual air intake set up off ebay for about 75.00.there is now a compressor,tank,and a set of air horns where the air box used to be.
