no heat
Old Sep 30, 2007 | 11:09 PM
rmeyer's Avatar
rmeyer
Default no heat
I have 1997 Dakota V-6 Magnum 4x4.First let me say the A/C works great andI have the had the heating and cooling systems flushed with the heat on to get the core flushed out also. I have also disonnected the hoses to theheater core and flushed it seperatly.Here is the probem, I have little to no heat. I can turn it to defrost and it blows warm for a second or two then it goescold, I thenturn it to the floor and I will get heat for only a minuet or two the it blows cold. here is the strange part most of the time I will get heat coming out if the side vent that hits the door windows. I have talked with a good friend who is a Mopar mechanic and he can't figure it out either. The heater core does not leak but occasionalyI hear a gurgling sound that seems to be coming from the passenger dash area or firewall. Has anybidy else had this problem?
Old Sep 30, 2007 | 11:33 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: no heat
Did you ck the t stat?? maybe stuck open, causing no heat. Also ck the firewall for a acc valve for the cooling system. That valve would be on the pass side if there is one.
Old Oct 1, 2007 | 12:50 AM
varsis's Avatar
varsis
Default RE: no heat
Probably just didn't get flushed good enough. Do a backwards flush on the heater core. I flushed mine for about 1-2 hours the other day and brown **** is coming out. Kept adding pressure till I had the hose on full blast. Each time I added pressure more would come...
Old Oct 23, 2007 | 11:47 AM
BigRedLemon's Avatar
BigRedLemon
Default RE: no heat
I'm having the same problem with my '97 V8. I took it to Midas to fix the heat...and they charged me $150 to install AC coolant!
Can the heater core be flushed without depressuring the AC? Also, can the AC compressor be swapped out without depressuring?
Old Oct 23, 2007 | 11:55 AM
United1's Avatar
United1
Default RE: no heat
1. yes.
2. no.
Both systems are independant, but you cannot swap the compressor without disconnecting the lines - meaning it must be depressurized
