CLUTCH FAN
Old Nov 7, 2007 | 12:47 PM
klings designs's Avatar
klings designs
Default CLUTCH FAN
Will some one send me the right way to find the directions to remove the clutch fan.. I want to put a new one on.....
I know it is on one of these threads somewheres...
THANKS
Old Nov 7, 2007 | 01:10 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: CLUTCH FAN
If you have an air hammer with a long chisel, that's the quickest/easiest way. Barring that, you need a fan clutch wrench, adecent pry bar (to help lock down the W/P pulley)and a set of thick leather gloves (lest you wind up with busted knuckles when if finally lets go).
They are R/H thread.
Old Nov 8, 2007 | 08:44 PM
DodgeDakota99RT's Avatar
DodgeDakota99RT
hey man i got a 99 rt that i took the clutch fan off of and put an electric fan on... if you can afford the extra bucks i would recommend that... i got lots of power and gas mileage back and with the gas prices as they are its worth it... if you want pics of my setup let me know...
anyways i went to auto zone and rented from their loan a tool program a clutch fan removal kit...
it was a big wrench that fits on the clutch fan itself... its pretty easy to take off just make sure you keep the water pump from spinning..
hope this helps
Old Nov 8, 2007 | 08:46 PM
rezonator's Avatar
rezonator
i would like to see pics of the electric fan conversion!!!!
Old Nov 8, 2007 | 09:06 PM
klings designs
for sure i would love to see pics.. what kind of electric fan do you have... doesnt the electric fan on their now work by itself with out the clutch one.... Or does that just cool off your radiator and trans cooler?
Old Nov 8, 2007 | 09:33 PM
klings designs
question question ........ anyone know how much a new clutch is..? and im sure it doesnt come with fan blades?
Old Nov 9, 2007 | 12:34 PM
lone_wolfin's Avatar
lone_wolfin
I too replaced my set up with a 2 speed fan from a 5.0 Mustang.....
I wired it so low speed will be turned on by the A/C and then high
speed it controled by a single wire switch in the upper radiator hose housing.
the switch is set to turn on around 218* and it will ground a relay
that i have wired up. The grounding of the relay will cause a low
current to control the higher current that runs the cooling fan.
WhenI mounted the fan, I turned it 90* do the fan is at the upper part
of the radiator.....
engine is soo much more responsive.....haven't checked mileage yet,
but horsepower and mileage will go up with less drag on the engine.
I also dont miss that irretating roar from thefan when i strart it now.
Old Nov 12, 2007 | 07:52 PM
tboss's Avatar
tboss
Hey wolf why dont yoiu put a schematic of how you wired it up on the forum and where did you buy the temp sending switch to make it operate. I want to install one of these on my boat to alarm me if the watyer temp in the engine is going to high , can I purchase one with temp of around 195 . tks terry------tboss
Old Nov 12, 2007 | 09:10 PM
Sixtysixdeuce
This its the schematic I drew for the fans I installed in my '78 Aspen coupe. The whole install is detailed in the general tech forum.
https://dodgeforum.com/m_1041851/tm.htm
