saging doors 2000R/t
Old Nov 14, 2007 | 02:10 AM
DAKAK's Avatar
DAKAK
Default saging doors 2000R/t
I justbought my 2000 dka online got it off the ship tonight (IM IN ALASKA) the guy didnt tell me about the doors saging 1st thing i notest @55 hole!. how do i fix
Old Nov 14, 2007 | 03:47 AM
01dakota's Avatar
01dakota
Default RE: saging doors 2000R/t
Yup, My drivers side door too. I was wondering the same thing. Pisses me off.
Old Nov 14, 2007 | 08:22 AM
4x4kota's Avatar
4x4kota
What do you mean by sagging... when the door is open it drops down a bit? I had an old s-10 that did that. If thats the case you need to replace the hinge.
Old Nov 14, 2007 | 10:41 AM
Nicegy525's Avatar
Nicegy525
remove the door and replace the pins and bushings in the door hinges. Common problem on cars with heavy doors.
Old Nov 14, 2007 | 11:17 PM
wlk404's Avatar
wlk404
If it's not sagging reallybad, you can put a floor jack under the door with a block of wood and jack it up. The door should be open just enough to clear the jamb. Watch out for the door to fender clearance at extreme lifts. Works great.
Old Nov 14, 2007 | 11:21 PM
wlk404's Avatar
wlk404
Oh yeah, don't put the block of wood on the outer panel edge. Place it on the flat part near the latch end.
