Anyone got any REAL fuel saver tricks??
Old Nov 30, 2007 | 06:24 PM
  #31
imnothot02's Avatar
imnothot02
Default RE: Anyone got any REAL fuel saver tricks??
get a moped they get like 70mpg cheap insurance too1
Old Dec 1, 2007 | 01:06 AM
  #32
jk240sx's Avatar
jk240sx
o2's in the 4.7 don't throw a code until they are dead. usually. also clean and check the connections
Old Dec 1, 2007 | 06:10 AM
  #33
HankL's Avatar
HankL
To really know if an oxygen sensor is partially 'poisoned' or misbehaving
you almost have to have a scanner
and watch what the O2 sensor does at different engine load conditions
and whether it is 'flipping' around in the correct way
because a 'healthy' O2 sensor does not have a stable voltage output.
I also think there is evidence that NTK brand name oxygen sensors
let the engine run slightly leaner and more efficiently
than richer running Bosch oxygen sensors.
Old Dec 5, 2007 | 02:57 PM
  #34
jk240sx's Avatar
jk240sx
Another factor is terain. i got great MPG when i lived in florida. now it utah with moutains it all changed.
Old Dec 5, 2007 | 03:23 PM
  #35
drjgarage's Avatar
drjgarage
My question about the tstat was partially answered. Why does a cooler engine get better mpg? I wish I could get 16-18mpg and I would be happy. How you doin' it Jonnymagnum? What tire air pressure can you run and still be safe on the highway?
Old Dec 5, 2007 | 06:35 PM
  #36
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i get 15-20 city-highway in the summer, with a relatively heavy foot, and remember that his is converted from km/liter (damn canadians and their conformist ideals) so its not perfect, i cannot say that it is far off, but conversions are never spot on, just my opinion
Old Dec 7, 2007 | 04:01 PM
  #37
drjgarage's Avatar
drjgarage
Could an O2 sensor be good but yet bad enouh to get les mileage? How much air pressure is still safe air pressure?
Old Dec 7, 2007 | 11:59 PM
  #38
steve05ram360's Avatar
steve05ram360
ORIGINAL: drjgarage
cold dense air makes more power... heat up the intake charge 15 deg less will = more power, more power with the same fuel = better mileage
Old Dec 8, 2007 | 12:02 AM
  #39
magnethead's Avatar
magnethead
Going to TMS (all highway) for the dickies 500 weekend, I got 24.23 MPG out of my V6.
#1: get a V6
#2: if you get a V8, dont get the 5.9/360
#3: empty your truck of non essentials to cut weight
and when I come home from work, i turn right thengo downhill a mile to get to my driveway. I've now started putting it in neutral when I hit 35 MPH, which i corner at 20 so doesnt take much, and shutting the motor all the way off. Then when i get to 15 MPH, i crank it back over- which is about when I need the powsteering back to get in the driveway (we have a 300 ft driveway). Plus i go exactly the speed limit or just under, regardless of who's on my bumper. And i put an egg under the gas pedal so i can't really push on it too far (next trick might be a throttle stop on the TB lol). I'm getting about 16-17 city.
Old Dec 8, 2007 | 07:04 PM
  #40
shrpshtr325
THE ULTI-MOD
it also helps that you have a 4x2, i had a 4x2 cc v6 and i was getting 17 city consitantly, now i get about 13-14 (its winter) with a 4x4 and a v8, not complaining, but the bigger engine will get less mileage its a fact of life
