Tilt Wheel and broken wire
Old Dec 7, 2007 | 06:29 PM
Radman's Avatar
Radman
Default Tilt Wheel and broken wire
My 02 V8 was giving me fits for weeks. I thought the Speed Sensor was my problem so I replaced
it. It didn't help at all. Iasked for help on the Dodge Forum web site. That didn't give me much
help either. Iended up getting it fixed at a local shop. Hereare the results I posted on the Dodge
Forum site.
Well guys it be fixed... The problem as to why the
ABS, AIR BAG and BRAKE lights would not clear
after start up PLUS, loss of SPEEDOMETER, no duct
control with your heating/cooling system (stuck in
defrost)was a broken wire off the ignition switch.
It took a few hours of trouble shooting plus
air bag and steering wheel had to be removed.
Also had the stock muffler replaced (is was
ready to fall apart) and had a "Cherry Bomb"
part # 88109 (Two output pipes) with new tail
pipes installed. I had them run side by side and
both exit behind right rear wheel. It sounds
nice! Not loud, just nice.
The rear diff pinion seal was also replaced.
All this came to the tune of $659.03 plus tax.
I'm sure the stealership would have been a TON
more.
Now I can put my little 79 AMC back to sleep for
the winter...
