Brake Lights Sticking
Old Dec 9, 2007 | 02:08 AM
geoffb123's Avatar
geoffb123
Default Brake Lights Sticking
So after I hit the brakes, park the truck, and turn everything off, my brake lights are still on. I even tryed pulling up on the brake pedal to see if that fixed it. This only happens sometimes, not all the time. Whats goin on here? I've been told its the brake light switch, but im not so sure. Any other ideas?
Old Dec 9, 2007 | 11:49 AM
f0x672's Avatar
f0x672
Default RE: Brake Lights Sticking
thats the first thing i would check, if it ws a short, the lights would be on all the time, or if the ground was bad, they wouldnt come on at all
Old Dec 9, 2007 | 03:21 PM
geoffb123's Avatar
geoffb123
Well they just seem to stick. I mean after a while they will go off and work normally again.
Old Dec 9, 2007 | 03:48 PM
bbcrack's Avatar
bbcrack
on most vehicles there is a button that becomes depressed when the brakes are pressed.it can stick. i have fixed it on different vehicles with wd40
Old Dec 9, 2007 | 03:56 PM
Rakaric's Avatar
Rakaric
yea there would be a box lookin thing on the stem of your brake pedal. It twists off and it is connected to a wire harness. Look at the button thing to see if it sticks. I found this thing when I was working on the remote starter system. Remember...when the button is pushed down, the lights go off.
Old Dec 9, 2007 | 05:01 PM
geoffb123's Avatar
geoffb123
I'll try with some wd40 and see if that works. I mean if the brake light switch went wouldn't they be sticking all the time.
Old Dec 9, 2007 | 08:27 PM
magnethead's Avatar
magnethead
not always. Switch contacts can be wierd about that
Old Dec 9, 2007 | 08:46 PM
imnothot02's Avatar
imnothot02
skip the bs, and pissing ppl behind ya off : )the switch is 15 bucks tops...
Old Dec 10, 2007 | 12:30 AM
geoffb123's Avatar
geoffb123
Ha ha I agree. Just might go ahead and do that. How hard is it to change the switch
Old Dec 10, 2007 | 12:33 AM
Rakaric's Avatar
Rakaric
shouldn't be hard at all. I mean the harness removal would probably be the most pain in the ***, but I think that harness is one of the easier ones to disemble. I think it's one of those lock type harnesses.
