AWD 2002 Dakota
Old Dec 13, 2007 | 02:25 PM
bbcrack's Avatar
bbcrack
Default RE: AWD 2002 Dakota
you need a little bit of slippage to allow the case to pull correctly in the front end i hav an open diff up front...shouldnt that allow it to slip enugh?
Old Dec 13, 2007 | 05:34 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the trucks do not have an open diff in the front from the factory, if you installed one than it has it, or if it has AWD it has an open diff in the front otherwise the fron diff is locked, put it in 4 hi on dry pavement and try to turn real tight like full lock and it wont do it, or if it will it will skip and you can hear tires squeal because they are slipping, and there will be a knocking fromt he front end that you can feel in the steering wheel. this happens because the front diff locks when you engange the 4hi setting so give you better traction in the snow/mud/whatever your on
Old Dec 13, 2007 | 07:26 PM
Nicegy525's Avatar
Nicegy525
just curious as to why it wont turn lock to lock on pavement but it will on dirt. My blazer did that
Old Dec 14, 2007 | 10:14 PM
bbcrack's Avatar
bbcrack
well i guess there was something i didnt kno lol. im just curious now...is it more like an elocker or a like a clutch type limited slip?& what axle is that diff similar to? dana 35? dana 44?
Old Dec 14, 2007 | 11:17 PM
shrpshtr325
THE ULTI-MOD
i assume that its something that has a lock in it, but i have never had mine apart to see what it is, i just know that when i put it in 4hi/4lo it wont turn on dry pavement w/o squealing and skipping and that the only explanation is that the wheels are turning at the exact same speed and traveling different distances(it happens when you turn its why differentials were created) and it must lock completely, cant be lsd clutches or you would be able to turn ok, AWD is probably LSD clutches i really dont know much more but ill try to help if i can
Old Dec 15, 2007 | 10:46 AM
steve05ram360's Avatar
steve05ram360
the 01 manual should have some good info on it...have a look in the manual and figure it out.
Old Dec 22, 2007 | 06:36 PM
rclay's Avatar
rclay
i have an awd 2003 quad cab 4.7 L . it says awd, 4hi, 4L. i drove in the snow the other day and it didnt feel like awd. i had to put it in 4hi. your answer is no, 2wd does'nt mean awd.
Old Dec 22, 2007 | 06:39 PM
magnethead's Avatar
magnethead
AWD and 4Hi arent the same either. AWD means it's 2wd unles there's a difference in wheel speed between the front and rear tires, then it'll start sending power to all 4. 4Hi means it's 4 wheel drive regardless what the wheel sensors say.
