Won't Start! Now with funny smell!
Old Dec 28, 2007 | 02:03 PM
ctjayhawker's Avatar
ctjayhawker
Default Won't Start! Now with funny smell!
That's it, really. Have a 2000 Dak, 3.9, auto, 4x4. Lately been having a problem with the electrical~~key-off drain somewhere, so that if it goes undriven for even 2-3 days, the battery's gone. Can't find it, neither can a shop. But that's not why I'm here. =)
THIS problem is totally different. Now she just won't start. Full battery (on the charger nearly 24 hrs). It's cranking, but it won't turn over. And when I'm done trying to start it, there's a funny smell, kind of like that propellant smell you get when an aerosol can is about empty.
Any ideas? Anyone? Anyone? Bueller?
Old Dec 28, 2007 | 02:12 PM
00DakR/T's Avatar
00DakR/T
Default RE: Won't Start! Now with funny smell!
Ok, for clarification....it turns over and doesn't crank or doesn't turn over?
Old Dec 28, 2007 | 02:13 PM
00DakR/T's Avatar
00DakR/T
Ok, for clarification.....it turns over but does not crank or does not turn over at all?
Sorry for the double post....had some network issues
Old Dec 28, 2007 | 02:24 PM
ctjayhawker
Mayhap I am confutzing my terminology. It tries to start, but won't catch. Occasionally, it'll ALMOST get it, (vroo--*)but then it just goes back to that annoying "no-I'm-not-going-to-start" rumrumrumrum.
Old Dec 28, 2007 | 09:24 PM
wink2873's Avatar
wink2873
check your fuel pressure at the rail, on the rail, drivers side towards the back there's a plastic cap. unscrew the cap and you'll see a schrader valve. turn the key to the on position but dont start it. then using something small and a rag press in the schrader valve, if gas sprays out you got fuel pressure. if not then it's something before that. have you checked for codes? could be a bad TPS sensor.
Old Dec 29, 2007 | 02:43 PM
ctjayhawker
I'll try that. No codes at all. UPDATE: on further screwing around, it was found that the fuel pump IS engaging, but ol' Bessie's getting no gas. I mean NO gas. Not even the aroma thereof. I'll try that valve bit and get back.
Old Dec 29, 2007 | 03:00 PM
ctjayhawker
Update #2. Nope. NO pressure through the evap test valve. So it must be aft of that. We (the dad-in-law) and I were thinking either the filter or a clogged line.
Old Dec 29, 2007 | 08:27 PM
imnothot02's Avatar
imnothot02
pump...? how did you check that..
Old Dec 29, 2007 | 11:45 PM
wink2873's Avatar
wink2873
filters are in the tank, hard to believe it would completely clog all at onceunless someone poured sand in your gas tank or something. you'll have to drop the tank to figure out anything though.
Old Dec 30, 2007 | 10:00 AM
ctjayhawker
When the key is turned, you can hear the pump engage. No flow, though. (Woo! Assonance!)
The shop has it now. Hopefully they can figure it out short of dropping anything, being as that is many simoleons.[:@]
