map sensor cel codes
Old Jan 3, 2008 | 05:10 PM
4x4kota's Avatar
4x4kota
Default map sensor cel codes
I threw a CEL Light and these are the codes that came up:
P0108 (M) Map Sensor Voltage To High MAP sensor input above maximum acceptable voltage.
P1297 (M) No Change In MAP From Start To Run No difference is reconized between the MAP reading at engine idle and the stored barometric pressure reading.
Does this mean that the map sensor went for a crap, or could there possibly be something else that istriggering it.I also checked the vacuum lines that run to the map sensor and they seem fine. any help would be appreciated.
Old Jan 3, 2008 | 05:34 PM
Nicegy525's Avatar
Nicegy525
Default RE: map sensor cel codes
sounds like a bad map sensor to me
