Throttle Body Spacer
Old Jan 20, 2008 | 01:56 AM
geoffb123's Avatar
geoffb123
Default Throttle Body Spacer
I've been looking into these things and I don't quite understand them. Im just curious as to if there actually worth it. Does anyone with these installed tell a difference in the hp and response of the throttle. Better acceleration, stuff like that. Just curious about them. Also what brand names to get. And how much they cost. Also, how hard is it to change them? I know my throttle seems kinda delayed when I hit the gas pedal it takes just under a second for the RPM to respond to the pedal movement. Not sure if this is normal or not. But would putting in a throttle body spacer help this at all?
Thanks
Geoff
Old Jan 20, 2008 | 02:59 AM
lil's Avatar
lil
Default RE: Throttle Body Spacer
They are a worthless overpriced paper weight.....end of story
Old Jan 20, 2008 | 10:13 AM
rtkota5point9's Avatar
rtkota5point9
Yup, on our trucks they do nothing.
Old Jan 20, 2008 | 11:02 AM
scandal669's Avatar
scandal669
try this for throttle response...i didnt try it, and to be honest, these kind of mods make me nervous. im more into bolt on stuff that i can take back off if it doesnt work for me.if i messed it up then id have to go buy new parts. but i have heard that this helps alot...try this link...http://www.v8performance.com/tipsandtricks.htm#TPS_Mod
Old Jan 20, 2008 | 12:11 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
throttle body space = nice paperweight
i dont feel like explaining why but just trust me if i need to explain let me know i will try
Old Jan 20, 2008 | 01:41 PM
geoffb123's Avatar
geoffb123
Thanks guys. Im glad I asked first before going out to buy one. Do you guys have any ideas as for why I have a delayed throttle response. Is there anything I can do to fix this?
Thanks
Geoff
Old Jan 21, 2008 | 09:18 AM
rtkota5point9
Try the TPS mod like was stated above. If done correctly it can help. Do you have an automatic? Are you sure you're not describing the pause it takes for the transmission to kick down?
Old Jan 21, 2008 | 09:22 AM
geoffb123's Avatar
geoffb123
It is an automatic. Even when im in park I can tell that its not really responding right. Unless its just me. I just tap the gas a little, then it responds 1 second after.
Old Jan 21, 2008 | 03:12 PM
Chris's Avatar
Chris
When was the last time you did a tune-up?
Old Jan 22, 2008 | 10:51 AM
rtkota5point9
Well if you blip the gas too fast and too much pedal it will always hesitate. Your basically adding too much air too fast with no load on the engineand it takes a second to compensate for it. When you are outon the road and give it a lotof pedal the hesitation you feel is more than likely the transmission shifting down.
