Cabin air filter
Old Jan 21, 2008 | 11:44 PM
ricbrk's Avatar
ricbrk
Default Cabin air filter
Does anyone know if the 2004's have a cabin air filter ? It's been like 7 degrees here for a couple days, and we noticed there is very little air coming out when you switch to the floor setting, and the dash vents seem weak also ? It still puts out excellent heat, just the velocity seems low even on thr high setting. The blower sounds good, and all the fan speeds work fine ?
Old Jan 22, 2008 | 01:10 AM
adamk's Avatar
adamk
Default RE: Cabin air filter
I am pretty sure I don't have one in my 2004. It does sound like something is plugged up though. You don't have any snow/ice covering the cowling do you?
Old Jan 22, 2008 | 12:41 PM
ricbrk's Avatar
ricbrk
My truck is kept in a semi heated garage, so I would expect any ice or snow to melt off it, but it has been real cold here. When my wife left for work this morning I put my torpedo heater out to wam up the garage to wash the truck. I'll run warm water over the cowl to melt anything off. If that doesn't work, I guess I'll start tracing vacuum lines and look for a vacuum leak.
Old Jan 22, 2008 | 12:44 PM
4x4kota's Avatar
4x4kota
To my knowledge there is not one in any of the 2nd gen dak's.
Old Jan 22, 2008 | 01:05 PM
Chris's Avatar
Chris
ORIGINAL: 4x4kota
Correct. Your blower motor might be going out, but I bet it is fine.
Old Jan 22, 2008 | 03:38 PM
jnwolf2000's Avatar
jnwolf2000
Sounds like a vacum problem. Sometimes my 03, takes a little while to switch, several minutes.
Old Jan 22, 2008 | 06:32 PM
imnothot02's Avatar
imnothot02
ur resistor is gna die
Old Jan 23, 2008 | 01:08 PM
02dakotakid's Avatar
02dakotakid
mine did the same thing. all i did was hit the bottom of the dash right below the hvac controls. mine hasnt had a problem since.
