Odd noise when turning, can't pinpoint.
Old Jan 22, 2008 | 08:08 PM
TomsDakota's Avatar
TomsDakota
Default Odd noise when turning, can't pinpoint.
Hi again guys.
We'll start off, it's a 99 Dakota 2WD 3.9.
The problem is, when taking moderate or greater right turns, there's an awful noise. It can be easily replicated if you stop, turn your wheel right, then accelerate - only when turning right though, when you straighten out it stops. So far we can't really pinpoint even if it's coming from up front or in the back - though it sounds pretty fair to say it's coming from the left side. It's a pretty violent noise, and you can really feel the vibration in your seat. If anyones drove on packed snow, it somewhat sounds like that. It's a roaring vibrating sound, it's pretty loud when it does it.
So far we changed the left front hub assembly (was under warranty anyways) and have just tried to do a visual inspection, it's a bit too cold here in Michigan to stay out there for too long at once.
Thanks for any help!
Old Jan 22, 2008 | 08:50 PM
noodle's Avatar
noodle
Default RE: Odd noise when turning, can't pinpoint.
Wow, i have the exact same problem, and I live in Michigan.
I cannot figure it out either, 95 Dakota 4x4 5.2 and when I take left hand turns I appear to have the same problem. Mine does not sound as violent as yours, mine sounds like a wheel bearing, but it isnt a constant sound. It goes hum hum hum hum.
Mine did this in the summer when there was no snow, and if i gently held my brakes while turning the direction it does it in, the noise will stop. Now that there is snow on the ground, if i try and do that the noise still continues, I figured it was related to the snow, but I have never really felt or heard this in any other vehicle I have driven.
Old Jan 23, 2008 | 10:07 PM
marchant's Avatar
marchant
please elaborate on your trucks... any lifts, oversized tires, etc? things like that could easily cause rubbing friction...
Old Jan 23, 2008 | 10:40 PM
TomsDakota's Avatar
TomsDakota
No lifts, stock size tires. New ball joints - upper and lowers. New brakes front and back.
It's just started the noise the last week or so, not after any mechanical change or anything.
Old Jan 23, 2008 | 11:38 PM
noodle's Avatar
noodle
stock setup. but it does sound like a tire rubbing but i know that it is not
Old Jan 24, 2008 | 12:22 AM
jonnymagnum's Avatar
jonnymagnum
hahaha mines doin the same thing it sounds like my tires are rubbing really bad, but they arent even close. I think my stripped caliperbolt came loose again. damn helicoils[:@]
Old Jan 24, 2008 | 09:00 PM
TomsDakota's Avatar
TomsDakota
ORIGINAL: jonnymagnum
Heh, been there done that. Cheap threads! That noise was a bit different though then this one, and had different characteristics.
Old Jan 24, 2008 | 09:23 PM
Nicegy525's Avatar
Nicegy525
could be in the steering rack
Old Jan 27, 2008 | 03:02 PM
TomsDakota's Avatar
TomsDakota
Well I figured it out guys, it was the transmission mount. The rubber part slid out of it's casing to the side, and it was banging against itself. Thanks for the help!
