Headlight High Beam Issue
Old Jan 27, 2008 | 11:48 PM
geoffb123's Avatar
geoffb123
Default Headlight High Beam Issue
So im driving home from my girlfriends house. I start my truck and wait 15min before I leave. In calgary its about -30 with the windchill. My high beams were working perfectly fine today. Although during the day it wasn't really as cold as it was now. So anyways im driving and I go to turn on my high beams, and neither of them come on. Just my low beams are working. I looked at the bulb and they didn't look like they were shot at all. Could a possibilty be that its to cold out for the bulbs to turn on? Its never been this cold before and its never happened. And like I said, they were working perfectly fine today.
Old Jan 28, 2008 | 03:50 AM
varsis's Avatar
varsis
Default RE: Headlight High Beam Issue
Check your fuses and the relays under the hood. Yea I know it's cold up here I live about 4 hours away from here. -31 right now without wind chill.
Chris
Old Jan 28, 2008 | 11:50 AM
geoffb123's Avatar
geoffb123
Could it being cold cause the problem though? They said today its -35 without the windchill, and with the windchill its suppose to get up to like over -40.
Old Jan 28, 2008 | 04:35 PM
geoffb123's Avatar
geoffb123
Just doing some researched and I looked into the multifunction switch. Is it a possibility that the switch went?
Old Jan 28, 2008 | 08:57 PM
varsis's Avatar
varsis
Could be. I would check the fuses with the cold weather one of them might have went. Sounds like a fuse though.
Old Jan 28, 2008 | 09:05 PM
imnothot02's Avatar
imnothot02
change the relay its proaly sticking
Old Jan 29, 2008 | 12:29 AM
geoffb123's Avatar
geoffb123
How much do the relays cost?
Old Jan 29, 2008 | 12:32 AM
varsis's Avatar
varsis
probably 10 bucks from napa.
Old Jan 29, 2008 | 12:43 AM
geoffb123's Avatar
geoffb123
Well first i'll check the relays. Then the fuses. Then the multifuntion switch. Go in order from easiest to hardest. Although the switch is just under the knee bolster. Not that hard to change. As for the relays, there under the hood in that black box right? Also how can you tell if its sticking or not?
