What trans do I have?
Old Feb 14, 2008 | 07:29 PM
99dakota318's Avatar
99dakota318
Default What trans do I have?
Ok I bought my truck about 5 months ago. The guy I bought it from told me he replaced the trans with a jeep transmission, he thought it was a 45re. I originally had the 42re (i think). Now I got the numbers off the sticker thats on the trans...how can I find out for sure what trans I have? the trans tag should be attached below....thanks
[IMG]local://upfiles/80182/149E40A70CC340B992A5365AD8B9D095.jpg[/IMG]
Old Feb 14, 2008 | 08:31 PM
varsis's Avatar
varsis
Default RE: What trans do I have?
Hi,
The tranny could be a 42re, 44re, or 46re.
Old Feb 14, 2008 | 11:40 PM
moe7404's Avatar
moe7404
moe in wichita ks
get in touch with these guys. i have known them from the 60 s they are honest. 90% of ALL trans shops get parts from a & reds. they will know the answer to any question.
http://areds.com/
Contact: 1-800-835-1007
email orders: parts@areds.com
Old Feb 15, 2008 | 04:57 PM
99dakota318
Thanks moe I contacted them and I sent them a pic of my trans pan and they say its probably the A 500.
Old Feb 15, 2008 | 05:29 PM
99dakota318
Ok my question now is how much fluid does the A 500 hold? The reason I ask is that my pan has a slow leak and when I bought it from the guy he was adding a quart a month, since I have owned it I haven't had to add anything even though its still leaking. The fluid level is still very high but could it be that way since its got a different trans while using the same original dipstick?
Old Feb 15, 2008 | 06:09 PM
varsis's Avatar
varsis
Are you checking it in neutral and on.
Chris
Old Feb 15, 2008 | 10:23 PM
99dakota318
I check it how the manual says...at operating temp let it sit for 30 sec. shift between neutral and drive I believe and put it back in neutral and then check.
Old Feb 16, 2008 | 04:28 AM
varsis's Avatar
varsis
I would just seal up the leak, simple to do:
Get under there, unbolt all of the pan bolts except one corner 1 (expect to get some on u) Support the other side once there is enough room to put a jack or something to hold it.
Now once all but the corner one are off. slowly undo the one bolt a little bit and move the jack to the middle and lower it a bit allow some of the corner to leak out. Now you have a pan full oil, either keep doing this or undo the bolt completely, and dump it would from the pan (balance or something on the jack. )
Get the appropriate oil, gasket and filter and just do the change while your add it. If you plan on doing a service soon after, maybe opt, for a tranny plug, you can buy ones to put in there, i should have done it on mine, but never got around to it.
Old Feb 16, 2008 | 09:24 AM
99dakota318
I'm hoping to get rid of all of the trans fluid maybe this summer and put the amsoil ATF in. So I'll probably do it anyway. Thanks
