Airbag suspension!
RE: Airbag suspension!
I dont know if you guys saw it, but the march issue of Sport Truck Magazine has a small write up on an air bag kit for the Dakotas. Its from Chassis Tech. Everything comes in the kit. Obviously not to extreme but for someone that wants to do it and doesn't know much about it this would be great. Fits 97-04. http://airbagit.com/product_info.php?products_id=3440
i've done some more research, i might be going with a wishbone link instead of the triangular,
they're the same thing just one bar with three mounting points instead of the 2 bars and 4 mounting points for the triangular
i'm also looking into a watts link but no simple kits exist, the parts would most likely need fabbed
heres the digital air management unit i'm gonna be running
The DHC-2102 offers the best of both systems! Vehicle height sensors as well as air pressures sensors are constantly being monitored by the DHC-2002 to offer absolute precision control of the air ride system. Kit includes 4 height sensors as well as 5 pressure sensors (0-150psi included for each air bag, 0-400psi for air tank). All systems have the availability to be controlled remotely through the use of ARR-2000, 6-button remote system.
http://www.dakotadigital.com/index.c...rod/prd501.htm
and i will be getting aluminum tanks, and super re-inforcing the rear so as to limit any risk of blown tanks if i get rear-ended, at 200 PSI apiece, not to mention not being able to drive withou air, they're gonna stay safe
hey im lookin into the same thing for my dakota r/t its sitting on 22's right now and i wana put it on bags anyone who knows the best parts to get for it and where to get them would be awesome. i looked into a couple bolt on kits but i am kinda scared about swish cheesing my frame. thanks for all the input guys!!
you're gonna have to cut a notch out of your frame above your axle, at least
bolt-ons can either hurt or help you
if you want it to last you should go with a weld on kit,
and dakota parts are not easy to find, most bagged 'kota guys i know fabricate there own stuff
and you will most likely have to ditch the 22's
unless you're a master fabricator
no offense to DF but there are very few low truck guys in here
i'll put some info together for you.
