P0121 code
Old Feb 14, 2008 | 11:51 PM
warfel87's Avatar
warfel87
Default P0121 code
P0121 (M) TPS Voltage Does Not Agree With MAP TPS signal does not correlate to MAP sensor signal.
P0121 (M) Accelerator Position Sensor (APPS) Signal Voltage Too Low APPS voltage input below the minimum acceptable voltage.
I got this code on my truck today. Im not real sure what this means. Anybody got any suggestions or can offer any help.
thanks
Old Feb 15, 2008 | 06:50 PM
imnothot02's Avatar
imnothot02
Default RE: P0121 code
id start w/ checking your grounds...
Old Feb 22, 2008 | 02:32 PM
DakFlOw's Avatar
DakFlOw
I had that same code pop up... i noticed that when i was driving on the highway the tac would jump uncontrollably like someone was steppin' on the gas...i took my truck into a local shop and they said that the Throttle Position Sensor voltage was low...$150 later truck runs like it used too
