45RFE shift problems
Old Feb 15, 2008 | 08:34 PM
cmr's Avatar
cmr
Default 45RFE shift problems
I'm having trouble with a 2002 dakota AWD 4.7 with 45RFE trans. At times it will sound like the trans slips when taking off, and it will go into limp mode, and the check engine light will come on.Ithas onlydone this before it reaches full operating temperature. If I really baby it until it warms up, it seems to work fine. Another problem I've had, is it has slammed pretty hard on a downshift at around 25 - 35 MPH, and go into limp mode immediately. In both cases, I can shut the engine off, and restart it, and it shifts fine. Any ideas on what could be causing this?
Old Feb 16, 2008 | 12:21 PM
varsis's Avatar
varsis
Default RE: 45RFE shift problems
sounds like a seal leaking or something isn't working properly, since this is a full auto tranny and bandless, I would go to the deal or someone with a computer to check this out. You could always try some lucas to swell up the seals to let it hold off for awhile if this is problem, but that only helps for a bit.
Old Feb 16, 2008 | 02:48 PM
moe7404's Avatar
moe7404
moe in wichita ks
get in touch with these guys. i have known them from the 60 s they are honest. 90% of ALL trans shops get parts from a & reds. they will know the answer to any question.
http://areds.com/
Contact: 1-800-835-1007
email orders: parts@areds.com
