Transmission problem?
Old Feb 20, 2008 | 09:14 AM
4x4kota's Avatar
4x4kota
Default RE: Transmission problem?
I was thinking that the stalling is caused by a vacuum leak, mine used to do the same in reverse and when turning full lock when goin really slow. Found a vacuum leak, fixed it and it's been fine since.
Old Feb 20, 2008 | 05:28 PM
moe7404's Avatar
moe7404
moe in wichita ks
i was talking to a cat telling him what little i knew about trans. he said that his mech. took OUT the check valve in the coolant/lube line, at the rad. this might be a good idea for all dodge trans. what think?
Old Feb 20, 2008 | 06:14 PM
olsarge's Avatar
olsarge
Good chance that your torque converter is sticking in lockup mode due to low transmission fluid.
Old Feb 20, 2008 | 09:32 PM
pumpkinheaver's Avatar
pumpkinheaver
What are the odds that my truck has the wrong dipstick? The fluid level was low but I added a little at a time untill it was in the hash marks when hot and in neutral. It seems better but still acts up on and off. If I had the wrong dipstick and the level was low then?..... Could the fluid just be worn out? I bought the truck used and don't know when it was changed last or if it was ever changed.
