Spark Plug Gap
Old Feb 20, 2008 | 06:17 PM
chuckb218's Avatar
chuckb218
Default Spark Plug Gap
Does anyone know where I might find this information? I have a 1998 Dodge Dakota V6 automatic, 176,000 miles...still going strong no major problems!!! I am going to change the spark plugs, I have them...I just need to know if anyone knows the proper gapping? I have no book with this truck. Any help would be greatly appreciated. Thank you.
Old Feb 20, 2008 | 07:35 PM
moe7404's Avatar
moe7404
Default RE: Spark Plug Gap
moe in wichita ks
i have done a lot of experimentation with spark plugs. i have found that any gap more than .045 doesnt help. i have used .045 on dodge 318 and 360s i think that the engine in the dak now are close to the older engines. i have 2001 v 6 i had my mach, set my plugs at .045 seems to run fine. but i forgot to ask what brand he put in. i do know its not a champion. so i say .045 and if you drive hard use a plug that is one or two heat ranges colder. my mech. says that a platinum plug in dodge is a wast of money.
Old Feb 21, 2008 | 02:56 PM
scandal669's Avatar
scandal669
if you have the stock ignition in it, use the factory gap...you can ask a parts store and they can look it up on their computer orlook at the sticker on the underside of the hood
Old Feb 21, 2008 | 08:37 PM
wink2873's Avatar
wink2873
it should say under the hood. I believe it's .040 if you have stock ignition.
Old Feb 22, 2008 | 08:34 AM
steve05ram360's Avatar
steve05ram360
autolite 3923's and .040 gap...
