Brakes
Old Feb 29, 2008 | 04:21 PM
01dakv686's Avatar
01dakv686
Default Brakes
i know this subject has been brought up many times but a couple months ago before it got cold here in upstate NY i went to change my pads and rotors and when i went to put the caliper bolts back in the holes were stripped like everyone elses does. I took it to work and tapped it out a little bit bigger then the caliper bolt and used a regular bolt cutting off those rubber boots.
After i did that i notice a pulsation in my pedal and a little bit of shaking, but when i put the new bolts in i made sure the bolts were tight and the caliper didn't move. Could they have come loose? And would i still be able to use the Helicoil kit everyone is talking about with this issue?
Old Mar 1, 2008 | 01:03 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: Brakes
I helicoiled mine in the summer.and it was fine uptill now. with in the past month it came loose and will not tighten at all. I'm lookin in junkyards for a new spindle, but cant find any. I havent priced out a new one yet, I hope they are not that expensive. I was thinking on just putting a tack weld in there to hold it for now until I get a new one. mine grinds and pulsates when ever I turn or release the brakes after applying them.
Old Mar 7, 2008 | 06:35 PM
troyanderson13's Avatar
troyanderson13
Default RE: Brakes
this must be common with dakotas because i did mine this past summer and the bottom caliper pin was stripped. parts stores sell self tapping pins though theyre a bit pricy around 25$. i bought one threw it in jacked it tight and its been fine ever since
Old Mar 7, 2008 | 07:15 PM
batman13's Avatar
batman13
Default RE: Brakes
hmmm. i just did mine, no stripping at all.
you guys are just too hard on stuff
Old Mar 11, 2008 | 04:09 PM
missedapeach's Avatar
missedapeach
Default RE: Brakes
Would this be the cause of my front end making a grinding noise and when brakes applied it makes a horrible clunk or creeking sound.
Already replaced upper/lower ball joints, inner/outer tie rods, shocks, idler arm,front axlehalf shaft,wheel bearing, and more. ????
Old Mar 11, 2008 | 05:34 PM
imnothot02's Avatar
imnothot02
Default RE: Brakes
it could, ur fine if you tourque things to spec,mine never had a problem, nor does my friend who works on them at the dealer...
Old Mar 13, 2008 | 07:20 PM
01dakv686's Avatar
01dakv686
Default RE: Brakes
would i still be able to use these helicoils even though i've made the hole a little bit bigger? Would it be a permanent fix? I've been looking online for new steering knuckles but everywhere i have looked has nothing. i searched this problem and saw that in one of the posts someone was gonna be charged 600 from the dealer. there is no way i'm paying that unless i really need to.
Old Mar 13, 2008 | 07:31 PM
imnothot02's Avatar
imnothot02
Default RE: Brakes
www.car-part.com
Old Mar 13, 2008 | 07:36 PM
01dakv686's Avatar
01dakv686
Default RE: Brakes
thanks for the link, but all those are for abs. i don't have abs. i don't think anyway. lol. every time i slam on the brakes hard enough they lock right up. i usually don't have to try to hard
