o1 dak c.a.i vs drop in
RE: o1 dak c.a.i vs drop in
what is the advantage to replacing the factory hose from the air hat to the box with an abs pipe?
i think my idea of having a hose go from the air box and straight out the grill is better than routing a hose all the way down thru the fender and out behind the fog light. its only about 1 foot of hose and it goesvirtually straightinto the air box rather than a twisted hose that is about 3 feet long...just my opinion.
also the foam filters have the worst air flow, even paper filters are alot better.
An average foam filter will flow 4.38 cfm/sq-in. A good paper filter will flow 4.95 cfm/sq-in. An oiled cotton gauze (K&N) will flow 6.03 cfm/sq-in.
Adding more air flow on our truck does not add more fuel. Our trucks (unlike GM and Ford, and a handful of other Chryslers) use a MAP sensor, not a MAF sensor. Because of this it cannot tell how much air is actually flowing through the intake. It can only base it's fuel amounts off the pressure at the manifold, which wouldn't change with more airflow.
So I think your loss in MPG is because subconciously you're heavier into the gas because of your new "performance" mod. Give it time and I'm sure you'll notice a slight increase in MPG overall.
And the reason most CAI's don't perform as well as just a drop in is for 2 reasons. Most CAI's use a metal tube. Although less restrictive, they are more prone to heat soak. Hotter air temps means less power. And most CAI's place the filter IN the engine bay which increases the air temp even more. Even with a heat shield, it's still in the engine bay. You need to get the inlet OUTSIDE the engine bay for it to have any effect. That's why the factory intake grabs air from the fender.
I'm fabbing up a new intake out of 4" metal pipe really soon, but to try and help with heat soak I'm having it cermaic coated. My filter is also placed behind the foglight, so I'll get some nice ambient temp air to work from. I don't have the option to put my inlet in the opening to the grill anyways since my intake is on the opposite side of the engine bay than most of you.
ORIGINAL: scandal669
In responce;I have not changed my driveing style,im 46 not 18 and I went with the drop in because of what you decussed,everthing eles is still fac.the only thing i may do is use a piece of flex to get air straight from the front but i will wait untill the computor learns the change in the filter.if u dont wait you will be chasing the unknown.thanks 4 your input.
