Metal In My Diff!!!
Old Mar 8, 2008 | 01:50 AM
fivehundo's Avatar
fivehundo
Default Metal In My Diff!!!
Hey guys! I've got a question...
I was just doing some routine maintenance on my Dakota. It's got 117,000 miles on it and I've been neglecting the scheduled maintenance on the Diff a bit, so I decided to change the fluid last weekend. I've been pretty good about that, typically but I've been somewhat busy lately. I always use "Mobile 1" syntheticand I always add the Limited Slip special lubricant. This time, though, when I went to wipe off the magnet in the bottom of the diff, there were some pretty large chunks of metal. One chunk in particular is about the size of a guitar pick, roughly. The other pieces are a bit smaller but still large enough to raise a concern.
I'm sure it's a longshot to try to determine what that material might be but if anyone has any ideas, I'm all ears.
The axle itself still seems to be working fine. There is a slight whinning that I was almost positive was the transmission, that had developed a leak after the shifter came loose and ran the fluid low but otherwise, the diff is working okay. I've been told that this is somewhat of a failing common to Dakotas but I haven't really had the chance to talk with any other owners that have had similar problems.
I guess I'm just going to drive the truck until the diff gives out. Then I'll just limp to the shop on the 4x4 axle.
If I do have to replace it though, is there an upgraded 3rd member that I might consider instead of just using OEM replacement stuff? Perhaps something a little more sturdy?
Old Mar 8, 2008 | 02:58 PM
spencea15's Avatar
spencea15
Default RE: Metal In My Diff!!!
There are alot of things it would be. You should take it to a good shop to find the problem and fix it.
Old Mar 8, 2008 | 03:07 PM
turbot_bird's Avatar
turbot_bird
Its going to be more money if you drive it till it breaks. You might even run the risk of needing a new housing if you wait. I would find the problem now before it gets worse. If there is a whine might be a bearing. Any vibration? Pinion have any play?
Old Mar 8, 2008 | 03:30 PM
imnothot02's Avatar
imnothot02
ever rotate ur tires, ya drive in 2wd all year never rotate, the fronts will be a different size than the rear, also ever drive on dry or not 100% slippery material when in 4x4?
Old Mar 8, 2008 | 05:07 PM
turbot_bird
Rotating the tires you are moving the fronts to the back so they will be equal
Old Mar 8, 2008 | 05:46 PM
jonnymagnum's Avatar
jonnymagnum
if you drive it till it breaks, you could do alot more damage. just take it to a shop and let them look at it.
Old Mar 8, 2008 | 08:44 PM
imnothot02's Avatar
imnothot02
ORIGINAL: turbot_bird
not if ya don't rotate them, ur rears wear quicker so they are smaller so turn faster..., can tear up a differential, ive seen it done
Old Mar 8, 2008 | 11:01 PM
big.bryant's Avatar
big.bryant
i just had this same problem. what it is is the limited slip clutch that disentigrated inside your differential housing. i got my truck out of the shop two days ago from the same problem. i also had some problems with a bearing being cloged so that might be what the whining is all about.
Old Mar 9, 2008 | 10:37 PM
TheePlaymaker's Avatar
TheePlaymaker
ORIGINAL: big.bryant
if you dont mind my asking how much did it cost you to get that done and did you get a whole new lsd unit or just a rebuild? what did you go with if you got a new lsd stock or aftermarket. i'm thinking of upgrading to an auburn sometime thats why im asking
Old Mar 9, 2008 | 11:25 PM
turbot_bird
ORIGINAL: imnothot02
yes, drive tires wear faster but rotating tires you move front to back, puting the fronts on the back dont tear anything up its if you take a single front and putit on the back then you tear it up. Thats not how you rotate tires they are done criss-cross
This:
1 2
3 4
Turns to this:
4 3
2 1
