tire pressure debate
Old Mar 13, 2008 | 03:28 PM
batman13's Avatar
batman13
Default RE: tire pressure debate
ORIGINAL: scandal669
batman13 and dragon8master----why should the rear tires have more pressure than the fronts? what does that do?
my rears are an inch wider and taller than the fronts, thats my only reason
Old Mar 13, 2008 | 05:46 PM
dragon8master's Avatar
dragon8master
batman13: I hope your truck is only 2wd, otherwise I don't recommend you use 4wd because you're in danger of destroying your transfer case.
I only have access to that guide at work, I wouldn't know where to actually get one. The one we have is out-dated and getting pretty rough around the edges from use. It only covers vehicles from 1994 - 2003. I wish we could get a new one like it, but the new ones dont list aftermarket fitments, only OE sizes. If any of you do happen to find one please let me know where.
Old Mar 13, 2008 | 05:51 PM
RoaminGnome's Avatar
RoaminGnome
OK now i feel retarded cause mine are the lowest. Mine are around 32-34psi. But does the fact that mine are mud tires make a difference (for road use that is). Maybe ill jack it up to 40 front and rear....
Old Mar 13, 2008 | 05:53 PM
jonnymagnum's Avatar
jonnymagnum
I keep mine at 40psi. and mine are 10 ply tires.
Old Mar 13, 2008 | 06:08 PM
batman13's Avatar
batman13
don't worry, id never go anywhere if i had 4x4, and my 2.5l
Old Mar 13, 2008 | 08:26 PM
moe7404's Avatar
moe7404
moe in wichita ks
i started driveing in 1965. i have ran pressures at the highest on the tire, unless i have a heavey load, then it goes to 5 to 15 higher. this is for tires less than 6 ply truck tires. my dad had some 6 or 8 plys on a heavy duty 3/4 82 club cab. the tire called out 70 psi, but dad didnt like the ride. the tire guys said he could run as low as 40, but he didnt want to go to low, so he used 50, and that worked good. cause he never maxed the load out. the presures on the door post are only for the tires that came on the truck, different tires may need different psi.
Old Mar 14, 2008 | 12:25 AM
TheePlaymaker's Avatar
TheePlaymaker
i think the last time i filled them up i actually put a few psi extra in the front cuz of the engine weight and the rake but i haven't checked them lately. i like having htem filled for best gas mileage but dont worry about wear seeing as i want them to wear down so i have a reason to get 32x11.50 M/T's lol.
Old Mar 14, 2008 | 02:37 AM
scandal669's Avatar
scandal669
ORIGINAL: RoaminGnome
i would think that your ride and mileage would be better if you added a few lbs... from this thread i am hearing that most people have theirs at around 40psi. my tires seem to lose a pound or two a month so ill see how my mileage, handling, and ride is at 40psi, then the second month they should be around 38psi and run them for another month like that...sounds like an interesting experiment. should have tried this before i started this thread
Old Mar 14, 2008 | 06:01 PM
RoaminGnome
Ya i think i will be bumping them up here soon. If i get better milage thats just a bonus but i wanna save my tires
Old Mar 15, 2008 | 08:07 AM
dragon8master
The pressures listed on the door sticker are for any tires of the same size listed. That's why that guide i mentioned also tells you the correct pressures to use for different tire sizes.
