Tires,tow hooks,lift,2004 dakota 4x4
Old Mar 15, 2008 | 06:17 AM
204dakota's Avatar
204dakota
Default Tires,tow hooks,lift,2004 dakota 4x4
Does anybody know if 275/70/16 bfgs tire size will fit my 2004 Dakota 4x4 stock with no lift? And has any one ever turned up the torsion bars and added a rear lief for more high, also tow hooks anyone try to put them on and how??
Old Mar 15, 2008 | 06:29 PM
RoaminGnome's Avatar
RoaminGnome
Default RE: Tires,tow hooks,lift,2004 dakota 4x4
Well jonnymagnum (i assume he will see this post soon ) Has done the torsion bar and blocked the rear. And 31x10.5 were a stock size those are gonna be a bit bigger so they may rub. But the cranking thetorsion barmight be enough so they dont rub.
I know Jonny has bigger tires and hopfully he can sese my talking bout him and will give a clearer awnser for you.
Old Mar 15, 2008 | 10:31 PM
jonnymagnum's Avatar
jonnymagnum
I have 265/70-17's (32x11.5) on mine. I cranked the T bars and put 2" blocks in the rear. mine rub a lil bit when turning at full lock. I just trimmed a lil bit off my front bumper so they would clear. and it all depends on the back spacing of the rims too.
Old Mar 15, 2008 | 11:07 PM
BlackOut04's Avatar
BlackOut04
i have an 04 4X4. i cranked the torsion bars to level out with the rear. i have 265/70/16s on mine. i tried 285/70/16s when it was bone stock and they rubbed when turning. but im going to get the 285/70/16s on one day.
Old Mar 15, 2008 | 11:32 PM
04firedak's Avatar
04firedak
i wonder im looking at some tires and they are 265/75/r16's
if i crank the torsion bars should i be ok?
i wasnt sure since stock tires at 70 while these are 75
help?
Old Mar 15, 2008 | 11:51 PM
BlackOut04's Avatar
BlackOut04
Its hard to say because i think 265/75/16s are about an inch bigger in diameter than the 265/70/16s. i think you should be alright, but i would get a second opinion before buying them.
Old Mar 19, 2008 | 03:49 AM
jlking21's Avatar
jlking21
i have 265/75/16s on my dakota. stupid tire place couldnt read. i didnt crank up the torsion bars. they are really close to rubbing and have only heard them rub while off road at full lock, never on the street.
Old Mar 19, 2008 | 01:40 PM
ZiggyNeon's Avatar
ZiggyNeon
make sure you check and see what width your rims are, mine from the factory were 16x8 so i have no problem putting the 265/75s i have on it now
no rubbing at all that i can tell, no marks or noise...and the guy that put them on said i will definately rub....
i have the t bars crankd and blocks in the back
