Transmission & Rear End Noise
Old Mar 23, 2008 | 06:57 PM
usry28's Avatar
usry28
Default Transmission & Rear End Noise
I have a 99 Dakota 3.9 V6 Automatic. The transmission does not shift from low to second the way it should (hesitates) and slips occasionally when first starting off. If I shift the transmission manually it acts completely different & does not slip. I also hear a roaring noise from the rear of the truck. Do I have a transmission issue or a differential issue? Please Reply
Old Mar 23, 2008 | 07:05 PM
imnothot02's Avatar
imnothot02
Default RE: Transmission & Rear End Noise
both how long since tranny and rear end were serviced?
Old Mar 23, 2008 | 07:13 PM
usry28's Avatar
usry28
Both were serviced two weeks ago. Problem already existed. I just purchased the truck & knew the problems existed. Just wanting to have the repairs made, but thought I would ask some questions from experienced Dakota owners first. What do you recommendrepairing first, Tranny or Differential?
Old Mar 23, 2008 | 07:52 PM
spencea15's Avatar
spencea15
maybe both
Old Mar 23, 2008 | 08:06 PM
usry28's Avatar
usry28
What about used transmissions from a reputablesalvage yard?
Old Mar 23, 2008 | 08:27 PM
moe7404's Avatar
moe7404
moe in wichita ks
get in touch with these guys. i have known them from the 60 s they are honest. 90% of ALL trans shops get parts from a & reds. they will know the answer to any question.
Contact: 1-800-835-1007
email orders: parts@areds.com
as for the rear end, go to the magazine stand and get a 4x4 mag, they have adds from rear end shops, any of them should be ably to help. are you sure they put lube back in the rear end?
Old Mar 23, 2008 | 08:47 PM
imnothot02's Avatar
imnothot02
www.car-part.com
Old Mar 23, 2008 | 09:13 PM
varsis's Avatar
varsis
Sounds like your front band is in need of a Replacement or adjustment.
