MSD
Old Mar 27, 2008 | 11:13 AM
cleverusername's Avatar
cleverusername
Default MSD
I finally have the MSD ignition, blaster 2 coil and wires all set up and running GREAT on my truck. Im getting ready to change out my plugs and am looking for suggestions. I hear the autolites talked up a lot and am willing to give them a shot. What I need to do is find a colder heat range and they also suggest gapping them further apart. Has anybody had any experience with this and know what plug/heat range/gap works well with the MSD. I payed for it, now I want the most out of it.
thanks
Old Mar 30, 2008 | 03:26 AM
cleverusername
Default RE: MSD
so why hasn't anybody responded to this? did i post this in the wrong forum? i've seen a lot of posts about spark plugs and what not, and people sounding like they know what they are talking about, but either they don't or it just comes down to personal prefrence. i suppose any furter questions will be easy ones that everybody can chime in on and give their 2 cents.
Old Mar 30, 2008 | 09:54 AM
varsis's Avatar
varsis
Default RE: MSD
I think it might be because not many people have MSD. Thats the problem...
Old Mar 30, 2008 | 10:02 AM
JasonA's Avatar
JasonA
Default RE: MSD
You might ask MSD what they recommend...and then do some research. What are the stock plugs on your truck? Usually, the manufacturer builds the heat range into the part number scheme somehow. If MSD recommends one heat range colder, then you'll have to contact the plug manufacturer and find out what is the next heat range down in that same plug design. MSD will also have to give you guidance on enlarging the gap. This is MSD's product -- they should have done the R&D and they should be in a position to tell you how to make the most use of it.
Good luck, and let us know what they say, for future reference.
Old Mar 30, 2008 | 02:35 PM
wink2873's Avatar
wink2873
Default RE: MSD
autolite 3923's gapped at .045
Old Mar 31, 2008 | 07:00 AM
HankL's Avatar
HankL
Default RE: MSD
watch out for the MSD overloading the thyristor
that drives the ignition coil current and 'frying' it.
Because this thyristor is inside your PCM computer
if it dies
you will have to buy an expensive new PCM
Old Mar 31, 2008 | 10:35 AM
cleverusername
Default RE: MSD
thanks for the replys and insight. all i got from MSD was generic instructions and recommendations. i honestly didn't think about contacting them, that should have been the first thing i did. im a dummy, so now that i put that out there, you can't hold it against me. i'll check with them and see if they have done any further research. i'll let you know what i find out. thanks again for your help.
