Amsoil Engine Flush
Old Mar 31, 2008 | 06:26 PM
TheePlaymaker's Avatar
TheePlaymaker
Default Amsoil Engine Flush
Well not to ruffle anymore feathers on the oil argument we have going on over in the oil thread but i was just wondering if anyones tried this. I'm thinking of doing this, as it would only cost an extra oil filter and 6 bucks for the flush stuff. Heres a link if you've never heard of it before. If i do decide to try it ill let you guys know.
http://www.amsoil.com/storefront/aef.aspx
Old Mar 31, 2008 | 07:43 PM
moe7404's Avatar
moe7404
Default RE: Amsoil Engine Flush
moe in wichita ks
the most important thing about oil is to have lots of zinc in the oil. i have done some searching on the internet on oil, filters, additives. i like to have oil as thick as i can and it still start in cold. so here is what i use, 2001 dak v6. Valvoline premium blue 15w-40 oil it has lots of zinc in it. Purolator PL 14670 PURE ONE filter, short ver same length as a fram ph43, use only a PURE ONE filter that is shown by the P in the part no, the long version is PL 30001 the long ver is the same length as a fram ph8a, may not fit all frames. under NO conditions use a fram filter. then you need to go to zddplus.com site and get some zinc from them. my truck starts ok in the winter, but we normally dont get below 0 f.
i did have trouble with 20-50 not wanting to turn over in the winter.
Old Mar 31, 2008 | 08:34 PM
TheePlaymaker
personally i use mobil 1 full synthetic high mileage and a mobil 1 filter, i've read to many horror stories to ever use fram. and i've read that the 4.7's dont like thicker oil so i stick with the suggested 5w-30 in the winter and then run 10w-30 in the summer. anyways i've got all that stuff figured out i just was wondering if anyone had any experience with the amsoil engine flush stuff cuz i wanna try and flush out any sludge that is built up im just semi worried that it may clean up sludge then clog something. thats the main reason im askin
Old Mar 31, 2008 | 08:44 PM
JasonA's Avatar
JasonA
There's nothing harder on an engine's lubrication system than thick oil. You're doing the right thing by using 5W-30 in the winter. Why are you switching to 10W-30 in the summer? To be brief:
An engine is designed for a certain oil viscosity. In our case, 30 weight when warm. That's in the neighborhood of 10 cSt (centistrokes). The Mobil 1 5W-30 product is 11.3 cSt, at 100*C (212*F). This can be found on every motor oil's PDS (Product Data Sheet). Look at the viscosity of even a synthetic 5W-30 oil when "cold". Mobil 1 5W-30 is 64.8 cSt at 40*C (or about 100*F). Yes, folks, that's the same scale (cSt). Even a synthetic 5W-30 oil is MUCH MUCH thicker down at just 100*F than it is at normal operating temperature, or about 212*F.
What would be ideal is a fluid that's about 10-11 cSt when super cold, and 10-11 cSt when super hot. The current state of oil chemistry hasn't gotten us there yet, but we're closer than we have been. There are some really super 0W-30 oils and 0W-40 oils out there that totally out-flow older 10W-30 oils for example. Putting super thick oil into your engine is murder to the lubrication system. Moe, if you want to run a 40W oil, at least use a 5W- or 0W-40. There's a reason Dodge doesn't specify a 15W-40 for these engines, and it does so only for the diesels. Their bearing clearances are designed for it. These engines' clearances aren't.
If you want to add a shot of ZDDP, fine...but your engine would in all honesty be much better off by you spiking a 5W-30 oil (or even a 10W-30 oil) with ZDDP than a 15W-40. If you really want to run an HDEO (Heavy Duty Engine Oil), Shell's Rotella is available in 10W-30, and is available from Wal-Mart (at least from mine). It's also available, by the way, in a 5W-40 weight, as a synthetic. Your engine will really thank you for it (as will your battery, by the way).
Old Mar 31, 2008 | 08:52 PM
TheePlaymaker
well actually i haven't decided what im doin yet or why i'd switch to 10w in the summer i just know i put 10w in it when i got it because i didnt know that it took 5w. depends on how hot it gets but ill probably just stick to the 5w
Old Mar 31, 2008 | 09:30 PM
imnothot02's Avatar
imnothot02
bah humbug lol i wouldnt do it, you dont want all that crap leting go all at once and its hell on seals and gaskets
my.02
Old Mar 31, 2008 | 10:52 PM
ricbrk's Avatar
ricbrk
I'd be afraid of clogging the pick up in the pan. If after flushing, you could pull the pan and clean it out that would be different. I don't think I'd do it, but let us know how it turns out if you do.
Old Apr 1, 2008 | 12:55 AM
TheePlaymaker
hmm the same reasons why i was leary in the first place the whole clogging thing is what scares me the most. maybe ill just run some seafoam in the oil for like 10 miles before i change it. hmm decisions decisions
Old Apr 1, 2008 | 07:14 AM
JasonA's Avatar
JasonA
Honestly, I wouldn't do ANYthing to it. Put fresh oil in it, change it asoften as you like,and go.
Old Apr 1, 2008 | 07:57 AM
imnothot02's Avatar
imnothot02
Is their anybody else on here (this board)who is a mechanic!???????
