Engine hesitates when accelerating
Old Apr 3, 2008 | 07:29 PM
KodiakJeff5's Avatar
KodiakJeff5
Default Engine hesitates when accelerating
Howdy everyone. I've got a 2004 Dak quad-cab with the 4.7 in it. I recently added the K&N CAI and since then, I've got this really irritating hesitation when I apply gas from a stop. It hasn't died on me yet but it feels like it might be a spark timing issue or maybe it's getting too much fuel. Not sure what the problem is but it sure is aggravating. Any thoughts on what might be causing this?
Thanks in advance for any help.
Old Apr 3, 2008 | 08:06 PM
moe7404's Avatar
moe7404
Default RE: Engine hesitates when accelerating
moe in wichita ks
try putting itback stock. thats my 2 cs
Old Apr 3, 2008 | 08:07 PM
varsis's Avatar
varsis
TPS could be going too or something. Maybe check your o2 sensors while your at it.
Old Apr 3, 2008 | 09:54 PM
KodiakJeff5
TPS? Is that the throttle position sensor? I'm a retired USCG Avionics Tech but I'm no mechanic.
Change the oil? No problem.
Rotate tires? No problem.
I can handle the basic stuff but I'm not that familiar with all the mechanical lingity. Sorry. I'll try to catch up.
Anyway, that's two folks now that have recommended checking the O2 sensor(s). Reading through some other threads, I noticed lots of folks talking about them and referencing two, a pre-cat and a post-cat sensor. Should I check them both?
Also, is there a chance that I could have dicked up the sensor that I had to drill a hole for in the CAI?
I really appreciate the help! Thanks!
Old Apr 3, 2008 | 10:00 PM
TheePlaymaker's Avatar
TheePlaymaker
yep thats what the tps is and that would be my guess to. when i first got my truck last april it would hesistate and studder while cruising down the highway so i knew it wasn't just a noob at driving stick which i already new how to do to. mine was a combination of the tps and the ecm or pcm basically the computer was shot. had them both replaced under the 3 month warrenty id do the tps first tho because the steam clean they gave the engine is what fried the computer.
Old Apr 3, 2008 | 10:12 PM
KodiakJeff5
That's good-to-know stuff. Thanks.
I had to have the TPS replaced on a 2001 Ram that I used to own. Took the stealership two seperate visits to figure it out. The first visit was while the truck was still under warranty. The second trip, about a year later, they discovered that the TPS was bad. Guess who had to pay to replace it?... I'll give you a hint: It wasn't Anchorage Chrysler/Dodge...
The prob was that I live on an island in the Gulf of Alaska and you never get to drive over 55 mph and that's when the problem manifested itself. Never knew there was a problem with the TPS until I put the truck on the ferry to the mainland and got on the highway. It would buck at any speed over 65 mph. What a drag!
Anyway, thanks for the info.
Old Apr 4, 2008 | 07:05 AM
JBs DAK's Avatar
JBs DAK
Could be the TPS but, you said it happened AFTER you installed the K&N filter.
My bet is you over-oiled it. I would clean your Thoddle-Body 1st.
Use THODDLE-BODY cleaner, NOT, Carb-Cleaner. Then, see what happens.
Old Apr 4, 2008 | 11:00 AM
steve05ram360's Avatar
steve05ram360
I would clean the TPS (DIY writeup thread has a link) and set the voltage on it to .70~.75 volts at idle... (drill out the rivits & manualy adjust it with a meter. that should fix it. I bet its on the low side (.6v or so).
