Durango rear end
Old Apr 19, 2008 | 02:51 PM
BlueDAKSRule's Avatar
BlueDAKSRule
Default Durango rear end
Does anyone know if a 9.25 rear out of a98 Durango will fit a 99 Dakota? Calling around the junk yards only got me more confused. They say the interchange lists Dakota only for the rear ends.
Old Apr 19, 2008 | 03:57 PM
Spike300's Avatar
Spike300
Default RE: Durango rear end
I would think so all duragos are is an suv form of the dakota. Otherwise all the mechanics are the same
Old Apr 19, 2008 | 03:59 PM
batman13's Avatar
batman13
same axle in both trucks
Old Apr 19, 2008 | 09:47 PM
jonnymagnum's Avatar
jonnymagnum
ya, they are the same
Old Apr 20, 2008 | 12:13 AM
01dakota440's Avatar
01dakota440
spring perches are on the bottom for a durango and on top for the dakota. but i don't see why you can't just flip it over.
Old Apr 20, 2008 | 12:33 AM
spencea15's Avatar
spencea15
Some dakots have the spring perches on the bottom, mine does. Some durangos have the perches on the bottom like my brothers 9.25 had the perches on the top.
Old Apr 20, 2008 | 08:22 AM
JasonA's Avatar
JasonA
I think all Durangos were spring under designs (the springs bolted to the bottom of the axle). Durangos also used the spring perch as the lower shock mount. You have have to have lower shock mounts welded to the axle tubes to fit into a Dakota, since our shocks are mounted directly to brackets on the axle, correct?
