V8 throttle body question
Old Apr 26, 2008 | 11:25 AM
Jmageee902004's Avatar
Jmageee902004
Default V8 throttle body question
Would any throttle body 4.7,5.2, or 5.9 from a dakota or ram work on the switch onto a 3.9. i was just wondering because if i got it from a dakota i probly wouldnt need the trottle cable Right? also does it matter what gasket i get for it or are all the v8s and v6 the same gasket?
Old Apr 26, 2008 | 11:29 AM
varsis's Avatar
varsis
Default RE: V8 throttle body question
ORIGINAL: Jmageee902004
5.2 and 5.9 will work, you will need a throttle cable for the 5.9 throttle body for sure not sure about the 5.2.... Don't think you do.
Old Apr 26, 2008 | 11:39 AM
Jmageee902004
thanks, do you know about the gaskets, and will the stock intake work on it im going to upgrade but for now ive only got the stock.
Old Apr 26, 2008 | 02:14 PM
varsis's Avatar
varsis
stock will be fine.
Old Apr 26, 2008 | 07:38 PM
Jmageee902004
im not shure but would a 97 ram 5.2 throttle body work, not shure if the older years were any different
Old Apr 26, 2008 | 07:40 PM
varsis's Avatar
varsis
Should work, as long as it is a 5.2 magnum... Not an la, not sure if the la's were EFI either way...
Old Apr 26, 2008 | 07:46 PM
Jmageee902004
whats the LA and how can i tell the difference?
Old Apr 26, 2008 | 07:48 PM
varsis's Avatar
varsis
It's basically the engine before magnum and what the magnum evolved from.
But that one if it is for sure a 1997 it will work.
Old Apr 26, 2008 | 07:54 PM
Jmageee902004
i bought it from JOhns auto salvage and they said it was a 97 so i think thier pretty accurate. i just wasnt shure if thier was like a whole different design before the magnums that i could tell.
Old Apr 26, 2008 | 09:24 PM
Jmageee902004
Ok. one last thing the TB will work, but as for the cable which one do i have to buy the one coming from the straight back seems to work but thiers two up front one that goes to the right passanger side(BTW where does thatgo?)and one that goes to the drivers side which im assuming is the accelarator cable. just making shure I havent got a chance to go to the store and just wanted to make shure im buying everything so i dont have to go back.
