AC not blowing out of vents on 03
Old Apr 29, 2008 | 05:19 PM
Maniac's Avatar
Maniac
Default AC not blowing out of vents on 03
My AC will not blow out of the vents on the dash all of a sudden, it worked fine last week. It only comes out on the floor and defrost ventsno matter what setting I put it on now. Is this gonna be expensive, or is it something simple?
Old Apr 29, 2008 | 09:09 PM
00DakR/T's Avatar
00DakR/T
Default RE: AC not blowing out of vents on 03
It sounds like not so simple. The A/C system doors (what switches it between defrost, vents, etc.) are all electronically controlled by the a/c control head. Odds are pretty good that you have a bad door actuator or a broken door both of which require dash removal to pull the HVAC housing. It is possible that the a/c control head needs to be recalibrated, which would also mean a trip to the dealer because you have to have a DRB to perform that function.
Old Apr 29, 2008 | 10:08 PM
Maniac's Avatar
Maniac
Well ****, that sucks!
Thanks for the info.
