HHO Fuel cell
from what i have seen most people just put them near the throttle body . just tap into it and let the engine draw the gas on demand.
i still want to do some bench testing and see what kind of amps its drawing and what the temp of the cell gets to after running for a bit.
lots of video on youtube and other sites to learn from.
I hope it works also. I have the rest of the items i need for a full install, but i want to bench test it a bit before i put iton the truck. So far its seems to be putting out about 1 litre to 1.5 litre per minute. that seems to be the norm from a larger cell. the one i made is much smaller and doing as well or better than some larger cells with plates. i am using a helix design and it is putting out alot of hho gas. hopefully i can figure out how to use it as a benefit to all of us. if you look up a man name stan meyer he was leap years ahead of us and he was using water only to fuel his engine. i am no scientist and have no degree in any kind of scientific field. i am just a guy playing around with hho gas and trying to get better mpg.
if anyone has any questions please ask and i will give you the little knowledge i have to give you a jump start.
[IMG]local://upfiles/71386/9239E0C44E01447F81925EDB10CC4F57.jpg[/IMG]
ORIGINAL: craig4465
I hope it works also. I have the rest of the items i need for a full install, but i want to bench test it a bit before i put it on the truck. So far its seems to be putting out about 1 litre to 1.5 litre per minute. that seems to be the norm from a larger cell. the one i made is much smaller and doing as well or better than some larger cells with plates. i am using a helix design and it is putting out alot of hho gas. hopefully i can figure out how to use it as a benefit to all of us. if you look up a man name stan meyer he was leap years ahead of us and he was using water only to fuel his engine. i am no scientist and have no degree in any kind of scientific field. i am just a guy playing around with hho gas and trying to get better mpg.
