Rear Wheel Speed Sensor...
Old May 10, 2008 | 08:55 PM
varsis's Avatar
varsis
Default Rear Wheel Speed Sensor...
Okay, well I am not getting and speed on the speedo, so I am assuming I am missing the wires for this. Does this connect into the transmission harness part? Or is it separate from everything else?
I am trying to figure this out so I know how fast I am going... Would be nice you know.
Any help is appreciated. Another thing, but isn't a problem, the OD OFF light is always on, but the od button works.
Chris
Old May 11, 2008 | 10:27 PM
440shadow's Avatar
440shadow
Default RE: Rear Wheel Speed Sensor...
the speed sensor should be on top of your rear diff
Old May 12, 2008 | 12:28 AM
varsis's Avatar
varsis
Well, I can't find anything wrong. Does anyone have any ideas why it might not work? A ground ect..?
Old May 12, 2008 | 12:22 PM
440shadow's Avatar
440shadow
have you checked the rear wheel speed sensor it self.
Old May 12, 2008 | 01:51 PM
dodgerules86's Avatar
dodgerules86
I believe the rear wheel speed sensor is used only for the ABS. There should be a sensor on either the transmission or transfer case.
Old May 12, 2008 | 05:52 PM
varsis's Avatar
varsis
oh, I guess I have to wire in the sensor, maybe It got pulled out... or something... Some stuff has been wired differently, but this harness has ABS, and Mine doesn't...
Old May 31, 2008 | 07:03 PM
hellraiser775's Avatar
hellraiser775
I had a problem with the speedo on my 04 and it turns out that the sensor on the top of the rear diff had been broken off. I replaced this sensor, it wasn't much bout 40 bucks and the speedo worked fine after that.
Old Jun 2, 2008 | 01:32 PM
yellowjacket99's Avatar
yellowjacket99
My experience with a bad rear wheel speed sensor, is that your ABS light, brake light, and speedo won't work till you get up to a certain speed. I don't have ABS either. So do you have these symptoms, or just that the speedo doesn't work, and does it work at all? Mine wouldn't register anything till around 25 mph.
