PCM Question - Will a 97 2WD PCM work on my 97 4x4 - both are 318 Auto
Old Jun 13, 2008 | 01:12 PM
JohnnyYZ's Avatar
JohnnyYZ
Default PCM Question - Will a 97 2WD PCM work on my 97 4x4 - both are 318 Auto
Anyone know if the PCM's are interchangable. I have a lever for the 4x4 on the floor which would seem to be mechanical. Will it work
Old Jun 13, 2008 | 02:21 PM
JasonA's Avatar
JasonA
Default RE: PCM Question - Will a 97 2WD PCM work on my 97 4x4 - both are 318 Auto
According to the PCM schematic on Alldata (for a '97 Dakota), there are no 4x4-related inputs or outputs in the PCM. So it appears that you would be good to go there. You are correct in that it's all mechanical.
Old Jun 13, 2008 | 05:49 PM
JohnnyYZ's Avatar
JohnnyYZ
I went to 2 chrysler dealers. One Mechanic said it wouldn't hurt to try saying it may work. The second mechanic said it would not work as they are 2 different drivetrains. So I'm in a bind. I have found two 2wd PCM's and 0 4WD PCM's in the city I live in both at $100 bucks. I'd probably have to get it flashed as well for my truck. Chysler has found a new one in British Columbia at a price of $695 plus they would have to program it as well for another 100. What to do, what to do?
Old Jun 13, 2008 | 08:19 PM
440shadow's Avatar
440shadow
i will work, or let me say i used a pcm out of a 99 that was 4x4 with a 5.9, and i put it in a 98 4x2 that had a 5.2. i had my buddy flask the vin and it worked fine.
