Help with Gears!!!
Old Jun 14, 2008 | 11:31 PM
Megamanjs's Avatar
Megamanjs
Default Help with Gears!!!
Oaky now is the time to upgrade my rear end a bit.....considering my pinion and spyder gears are in peices. Okay it is a 97 Dakota Sport with R/T wheels 255/50/17. Might go larger in the future but not by much. It is the 3.9 Supercharged with 42re Auto tranny, 8.25 Open with 3.5 gears (According to my Glovebox sticker). I probably should find out my gears for certain but lets assume right now they are stock. I do a lot of highway driving with some city driving (Phoenix, so lots of traffic). I am looking for a good combo to do good on the strip but also on the road course and of course something that will not hurt my gas mileage too too much (I know i want it all). I am going to put a LSD in it since i tore up the diff also, not sure which one just yet. What do you guys recommend?
Old Jun 15, 2008 | 09:14 AM
JasonA's Avatar
JasonA
Default RE: Help with Gears!!!
I wouldn't go too short in gearing, considering the torque characteristics of these engines (mostly made in the lower 2/3rds of the RPM range). I think either a 3.55:1 or a 3.92:1 gives a fairly good mix of performance. I have the 3.55:1 gears in my '97, and my tires are quite a bit taller than yours (29" tall vs. 27" tall), and I still think a 3.55:1 is short enough. I probably wouldn't go shorter than 3.92:1.
Old Jun 15, 2008 | 03:03 PM
Megamanjs's Avatar
Megamanjs
That is what i was thinking. I was looking at the tire sizing i might go to and it is around 28" to 28.5". So, and i do a lot of highway driving also. Do you know of a good calculator to determine my highway speed at certain RPM?
Old Jun 15, 2008 | 04:07 PM
wink2873's Avatar
wink2873
you may just want to think about swapping the whole rear for an R/T rear end. that way you get a stronger rear, 3.92's and a factory LSD.
Old Jun 15, 2008 | 07:52 PM
Megamanjs's Avatar
Megamanjs
Dont R/T's come with all wheel disc too, that would be nice. Also dont those weigh a bit more?
Old Jun 16, 2008 | 07:44 AM
wink2873's Avatar
wink2873
i think only 03 R/T's came with disc brakes in the rear, but im not sure. and yes the rear is a little heavier but it's stronger, something to think about if you're going to be doing burnouts and racing, which if your 3.9 really is supercharged... you better be.
Old Jun 16, 2008 | 08:04 AM
JasonA's Avatar
JasonA
I agree with swapping an entire rear axle into it. The 9.25 came in non-R/T models also, after about 2000 or so (I don't know the actual break point).
Here's a good speed calculator: http://www.kabamus.com/garage/gears.html
Old Jun 16, 2008 | 12:14 PM
Megamanjs's Avatar
Megamanjs
What about an 8.25 with an Auburn Posi and 3.92's? I ask because i just found one here in PHX.
Old Jun 16, 2008 | 12:28 PM
JasonA's Avatar
JasonA
Sounds fine to me. I don't know much about the reliability (or not) of Auburn units, but an 8.25" axle with 3.92s should be just fine. Especially if you can get the whole thing for a couple hundred bucks.
Old Jun 17, 2008 | 11:35 AM
Megamanjs's Avatar
Megamanjs
Ya, he is debating selling it to me or not. Either way i will go with the R/T rear or an upgraded 8.25. Thanks for all your info and advice.
