}Project{ Battruck
Old Jun 30, 2008 | 03:16 PM
batman13's Avatar
batman13
Default RE: }Project{ Battruck
second compressor is bolted up,
just going through some setups as far as where to hook everything up at,
like the tank pressure sensors, front/rear lines whether or not to hook the tanks together as one or have 2 completely separate systems.
i'm also going to have a quick connect for air tools.
Old Jun 30, 2008 | 04:20 PM
batman13's Avatar
batman13
ok, questions figured out, now for the numbers:
0-200 psi in 7min
165-200 psi in 2min
it should not have to run from 0-200 unless i drain the tanks for some reason, i have a 165-200 pressure switch.
and it better not leak anywhere, if it does i'll know when i go to leave in the morning.
Old Jun 30, 2008 | 04:58 PM
batman13's Avatar
batman13
the new garage
i hate the rain
Old Jun 30, 2008 | 06:50 PM
batman13's Avatar
batman13
i will be running both tanks and comps as 1 system, with a leader hose running between the tanks and both comps and the pressure sensor hooked to one, then i'll run 2 lines to the valve block. and the last port goes the quick connector for tools.
sweet
i mean bizniss
Old Jun 30, 2008 | 07:19 PM
RoaminGnome's Avatar
RoaminGnome
Sweet deal. And thats a nice garage you got there.
Rain blows. Its that simple, I know we need it and all but its sooo annoying. We keep getting the random Tstorms here in NH.
Old Jun 30, 2008 | 11:33 PM
TheePlaymaker's Avatar
TheePlaymaker
thats awesome I used to not like lowered trucks but i really like lowered daks can't wait till its done its gonna be sweet.
Old Jun 30, 2008 | 11:38 PM
RoaminGnome
Ya know I was never a fan of low trucks either. But I gotta say Im a big fan of these trucks. I even considered getting a 2wd dak and lowering it and what not.
Old Jul 1, 2008 | 04:50 PM
batman13's Avatar
batman13
Old Jul 1, 2008 | 11:19 PM
bpm's Avatar
bpm
Just a suggestion...you should put a drain valve in each of those tanks,where the big plugs are at the bottom,you will get alot of water and you'll need to drain them frequently...
Old Jul 2, 2008 | 02:13 PM
batman13's Avatar
batman13
ORIGINAL: bpm
im going to be using water traps, most likely before the comps
i don't think i will use actual draincocks since they hang down quite a bit, and i better not get any water in these things anyways.
