need help p0601 2000 dakota v6
Old Jul 5, 2008 | 02:04 AM
explrcnvrtbl's Avatar
explrcnvrtbl
Default need help p0601 2000 dakota v6
i have ni\o idea what this is or how to fix it... says int something check sum error? what?!
Old Jul 5, 2008 | 02:06 AM
User's Avatar
User
Default RE: need help p0601 2000 dakota v6
sounds like a bad PCM to me.
EDIT: Try resetting the PCM and see if it goes away. If not looks lie you might be buying a new PCM.
Old Jul 5, 2008 | 03:45 PM
explrcnvrtbl
reset it yesterday, came back today.....
i want to try to unplug the pcm, and plug it back in? is that cool?
what about the battery? i am currently using a scanner rented from autozone.....
ive been looking around on goole, and everyone says pcm fried time for a new one... eek!!!!!!
is it possible it got fried while changing sparkplugs? my father in law has done his plugs and wires several times and thinks he may have an issue... the engine runs a little rough and he thinks that he has a plug that came out or a broken wire? could a bad pcm do this? is it possible he freid it? he has tried disconnecting the battery several times to fix it, and i am not sure if this is what hurt it or not. it is the only code showing
Old Jan 23, 2009 | 03:20 PM
jimbo74's Avatar
jimbo74
wow i need spellcheck, haha.... i got my original login fixed. any other ideas on this? from what i have been researching, i should try to have the computer reflashed by dodge first? then if that doesnt fix it, will need to obtain a new computer and need that flashed as well?
Old Jan 23, 2009 | 04:33 PM
f0x672's Avatar
f0x672
i doubt a reflash will do it, most of the time from my understanding, they just burn out.
Old Jan 31, 2009 | 04:22 PM
jimbo74's Avatar
jimbo74
thats what i figured. i found a place in florida that says they can rebuild mine for $300
http://www.chryslerecu.net/catalog/D...A/2002_rnr.htm
what do you guys think of this place?
any other suggestions?
Old Jan 31, 2009 | 04:49 PM
f0x672's Avatar
f0x672
id give them a call with your VIN and ask em how long will it take for the repair, etc. do your homework first before you commit to something. benefit so much better doing that.
Old Feb 7, 2009 | 02:11 AM
jimbo74's Avatar
jimbo74
may not need to buy a new one!!!!!
i met master tech, and he reprogrammed the computer using the drb3 scanner.
the CEL went off of wednesday and hasn't been back since. [prior, i could disconnect the battery and it would go away for the first start, but promptly come back on by the second start]
My FIL was able to take the truck to get its smog check, and the CEL stayed off, SO HE PASSED!!!
and was then able to take the printout to DMV and get his registration sticker & renewal on the spot!!!!
