hooking up my CB? New CB?
Old Jul 14, 2008 | 10:04 AM
ironcowboy's Avatar
ironcowboy
Default hooking up my CB? New CB?
Well i have an old CB i put in my 99 dakota, and i'm having trouble with it! I get tons of feed back, and when i key the mic i just get a high pitched whine. I think i might need a new CB, but not sure.
I have a magnet antenna hooked to the back side of my truck up on the edge...
~Samuel
Old Jul 14, 2008 | 12:57 PM
JBs DAK's Avatar
JBs DAK
Default RE: hooking up my CB? New CB?
I would think when you Key-up your mike, its too
close to the CB. That's the only time I get that type
of feedback.
Old Jul 14, 2008 | 01:58 PM
ironcowboy's Avatar
ironcowboy
That is what i thought too, but its as far away as i can get it (arm's length)
Old Jul 14, 2008 | 04:57 PM
f0x672's Avatar
f0x672
i had that trouble with mine, it was a bad mic, the wires in the cord over time just break or rub against each other and short out
Old Jul 14, 2008 | 06:03 PM
moe7404's Avatar
moe7404
moe in wichita ks
did you check the swr ?
Old Jul 14, 2008 | 08:02 PM
ironcowboy's Avatar
ironcowboy
what pray tell is a swr?
Maybe its the mic, i'll try picking up a new one and testing that.
~Samuel
Old Jul 14, 2008 | 09:17 PM
mikec04's Avatar
mikec04
SWR= Standing wave ratio. It is the ratio of radiated RF (radio frequency) out of the antenna compared to the amounmt of RF comming back to the radio. Ideally should be 1.5:.1 is generally accepted to be sufficient. With a high SWR (more than 2:1) you run a good chance of burning out the final amplifier. In CB, you are only working wiuth 7 watts out, so it's no big deal. One of my hobbies is amateuer radio. I've got a Yaesu FT2100 in my '98. Wired direct to battery, fused at battery on both lines (= and -) with another fuse on the + at the radio and putting out 55 watts on high power. SWR has to be right for that. ould destroy radio in 10 mim.
Find someone with a swr bridge (meter). connect swr bridge to radio, and antenna to swr bridge. check by keying mic. If high, trim antenna length.
Old Jul 15, 2008 | 12:07 PM
ironcowboy's Avatar
ironcowboy
Ahh, that helps a bunch! Now to find that meter, If i have to buy a new system, do you recommend anything?
Old Jul 15, 2008 | 08:16 PM
mikec04's Avatar
mikec04
My CB days are long gone. I do Amateur radio- HF (high frequency) with a Kenwood TS930SAT and the above mentioned Yaesu for 2Meter FM. To do this stuff you need FCC licensing.
