SAS dana 60's all around
Old Mar 24, 2009 | 06:37 PM
  #201
bpark8824's Avatar
bpark8824
I like how it still says v6 mag on the side lol.
But that thing is awesome varsis
Old Apr 10, 2009 | 10:54 AM
  #202
MonkeyWrench4000's Avatar
MonkeyWrench4000
Damn those axles are wide for that dakota, do you ride both lines on the road? lol That looks great though man congrats.
Old Apr 10, 2009 | 11:32 AM
  #203
magnethead's Avatar
magnethead
I nominate 6" Exhaust stacks....FTHOI
And I'd imagine the outside to ouside is probably in the 96" range. Our dually at home is 100" from outside rear wheel to outside rear wheel, so if you account for the 4" hub flip on both sides, that's about 92" from flange to flange......(Dana 70HD)
Old Apr 10, 2009 | 07:13 PM
  #204
varsis's Avatar
varsis
well im working on getting the drive line angles proper in the front right now. Turning the c's is harder than I thought it would be.
Also i think I am getting a lock right to put in! Front. Should pull through a fair bit.
Old Apr 18, 2009 | 07:31 PM
  #205
varsis's Avatar
varsis
attempted turning of the inner c's
Couple pics. btw thats 1/4" channel.
pics are still coming up.
Old Apr 20, 2009 | 03:48 PM
  #206
magnethead's Avatar
magnethead
trying to change the caster on the front???
Old Apr 20, 2009 | 05:12 PM
  #207
varsis's Avatar
varsis
yep. got em off though now:
Old Apr 20, 2009 | 08:14 PM
  #208
magnethead's Avatar
magnethead
how far do you have to move it? I thought the pinion has to be within 10 degrees of horizontal for proper oiling???
Old Apr 21, 2009 | 09:54 PM
  #209
varsis's Avatar
varsis
Got to sanding down the press fit part, and the rest of the axle for a paint job im thinking lime green! lol.
Old Apr 25, 2009 | 05:57 PM
  #210
varsis's Avatar
varsis
after a day of mudding and getting stuck...
PS box is leaking. Front drive shaft slipped apart (is back together just need a longer slip shaft.), and the rear one is hitting the gas tank skid plate (simple cut should fix it. )
