After throttle body swap help/suggestions
OK I found where i was supposed to be adjusting the tv cable. before i was only pushing the whole thing through the bracket, when the pedal was pressed the piece snapped into the bracket. So I removed the white clip so the cable will slide and found that the cable was already pushed back as far as it would go. i moved it up for kicks and it starting shifting at 1500rpms. Maybe the cable is not hopeless yet? I just need to find my 1/8" some how. i can push the cable back further but i run out of teeth and the clip will not refasten!
