Best fog lights?
what size is the stock hole in the bumper...my passenger side lens is cracked and filled half way with water and i wanna replace them with some brighter driving lights...is it 3.5" or 4" thanks guys
I had the Cyberwhite NAvigators by Pilot for about 2 yrs. Bright as heck but not a very sharp cutoff and one finally burned out. I now have 89 dollar Pilots, the kit that's advertised as being built specifically for the Dakota bumper. Sorry, don't have model nubmers in front of me. These seem to give a fuller light pattern and a sharper cutoff. No need to spend more than 60-80 bucks on a set no matter where you get them. If you want to spend real money spend it on driving lights.
anything between 3.5 and 4 inches should fit OK, the closer you can find to 4 inch diameter the better. The stockers are 3.5 but the adjustment screw mechanism takes up that extra .5 inch in the hole so there is no gap. If you get 3.5 inch aftermarket ones that usually have the adjustment screw hidden in the back you will have a gap and it won't look that great.
