Gas pedal related back fire?
Old Aug 28, 2008 | 08:43 PM
varsis's Avatar
varsis
Default Gas pedal related back fire?
Not sure whats going on but when I am driving and at a certain amount of foot into the gas the engine will go a 1000 rpm, back fire go another backfire and so on... Maybe rotor and cap? Or wires? coil? I don't know...
Any ideas? No oil burned. Im thinking maybe a rusty wire or something?
Old Aug 28, 2008 | 10:07 PM
rtdakota2001's Avatar
rtdakota2001
the little ring on my distributor was broken and for a while i was getting backfires after it rained. moisture was getting in through that bad gasket. check that.
Old Aug 28, 2008 | 11:46 PM
wink2873's Avatar
wink2873
sounds like you're running rich and the pcm isnt correcting it. check your o2's after you check ignition components.
Old Aug 29, 2008 | 04:58 AM
batman13's Avatar
batman13
mine did that for a while, i havnt driven recently enough..... but i havnt fixed it that i remember, but after regular maintenance it seems like its not happening as much as it used to
Old Aug 29, 2008 | 03:47 PM
varsis's Avatar
varsis
I changed the plugs recently and i thought it would fix it. I can watch the Tach go in like chunks...
when I pulled the plugs they were all nice and clean. I will check the rotor and cap last time I looked it looked like it was being melted... But not sure...
I Changed the coil last night, used some seafoam.
Reset the computer today, still no go... Only happens at a Certain pedal. I don't think it's moisture, but IL have a look.... It hasn't rained till last night...
I am not sure...
Old Aug 29, 2008 | 04:19 PM
batman13's Avatar
batman13
i have a leaky exaust or intake gasket, check those maybe...
if i have the problem, yours is not horsepower related
Old Aug 29, 2008 | 04:54 PM
varsis's Avatar
varsis
No power missing here. I think it's a bad rotor or cap. Maybe something else who knows. Il check the cap and rotor next.
Old Aug 29, 2008 | 05:42 PM
jonnymagnum's Avatar
jonnymagnum
my 99 dak did that awhile ago. when ever I was cruisin along and take my foot off the gas it would back fire. I changed the cap and rotor and it was fine after that. the tip of the rotor was melted. so I would look into that
Old Aug 29, 2008 | 07:41 PM
varsis's Avatar
varsis
I think that is what is the problem.
Old Aug 29, 2008 | 07:57 PM
varsis's Avatar
varsis
can I use dielectric gel on all the contact points on the cap / rotor?
